Hello - I wanted to see if I could use the "complete" node to monitor when certain events in the flow are done (basically, monitor when any branch of a flow ends). When I look at the nodes that can be selected in the "complete" node, I also see the subflows (which is great!)
The question is when does the complete node get the notification for sub-flow completion? The last "node" in both sub-flows shown above is another sub-flow (which has just the Pushover node). Also, if a node shows up in the selection list for the "complete" node, does it mean that it automatically supports notification?
I did do a Google search and also search here, but as you can imagine, the search results were somewhat meaningless. There was one example of using a complete node but it was very basic.
Thanks for your help.
