Hello every one
here I'm reading two variables in mqtt i want both in singe line how can I do
Can you rely on both of them coming in continually ?
If so feed them through a Join node
If not then put them into context variables and access them from there
Craig
yes data is coming continuously
As Craig suggested, I think you'll find you need to 'join' the two variables as although they are being generated continuously - they won't arrive or be processed by Node-RED simultaneously.
Take a look at this posting as it is very similar to your situation.
