Hi. Is it possible to enter a numeric value into the trigger from the dashboard for user change values? If yes How?
On dashboard, yes, use ui_numeric
Not directly, trigger is a server-side node, not a dashboard node.
I suspect what you want is a dashboard with a numeric input and when the user (changes number value -OR- clicks a button) for that value to be sent in msg.payload to the next node - is that right?
- Can you clarify exact requirements?
- What have you tried so far (show us)?
@jenicek welcome to the forum!
You need to explain a bit more. When you say
what node are you talking about? Have you got a small example you can provide showing the issue?
You could use the ui-form and specify a numeric field or the ui-text node and set it to numeric. Here are two examples for you
[{"id":"4b3bee481ddee85d","type":"ui_form","z":"5575de10a54432e0","name":"","label":"","group":"0d0d52388bfa9b29","order":1,"width":0,"height":0,"options":[{"label":"number","value":"numb","type":"number","required":true,"rows":null}],"formValue":{"numb":""},"payload":"","submit":"submit","cancel":"cancel","topic":"topic","topicType":"msg","splitLayout":"","x":460,"y":320,"wires":[["d5a1e4c8ca6ce5d2"]]},{"id":"d5a1e4c8ca6ce5d2","type":"debug","z":"5575de10a54432e0","name":"","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"true","targetType":"full","statusVal":"","statusType":"auto","x":650,"y":320,"wires":[]},{"id":"1dfc9e877d7a5293","type":"ui_text_input","z":"5575de10a54432e0","name":"","label":"","tooltip":"","group":"0d0d52388bfa9b29","order":2,"width":0,"height":0,"passthru":true,"mode":"number","delay":300,"topic":"topic","topicType":"msg","x":460,"y":260,"wires":[["9a7f6a2a0244ce27"]]},{"id":"9a7f6a2a0244ce27","type":"debug","z":"5575de10a54432e0","name":"","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"true","targetType":"full","statusVal":"","statusType":"auto","x":670,"y":260,"wires":[]},{"id":"0d0d52388bfa9b29","type":"ui_group","name":"Default","tab":"ead25aa0bfe0ccf7","order":1,"disp":true,"width":"6","collapse":false},{"id":"ead25aa0bfe0ccf7","type":"ui_tab","name":"Home","icon":"dashboard","order":1,"disabled":false,"hidden":false}]
Yes, that's exactly it. It is a control unit for an automatic solid fuel boiler - control of the application cycle. Change of fuel dosing values, change of emergency values, etc.
"id": "7eb3894d34189c95",
"type": "tab",
"label": "Automatika kotle",
"disabled": false,
"info": ""
"id": "4350539b6b93cbd6",
"type": "rpi-gpio out",
"z": "7eb3894d34189c95",
"name": "Relé podavače/Relay Feeder",
"pin": "8",
"set": false,
"level": "1",
"freq": "",
"out": "out",
"x": 1820,
"y": 100,
"id": "b077c631bd89e04e",
"type": "thermostat",
"name": "Provozní termostat/Operating thermostat",
"highLimit": "55",
"lowLimit": "50",
"x": 300,
"y": 80,
"ebe0e03ff8858218",
"e929974c20ac1b78"
"id": "7162467dd417d1af",
"type": "ds18b20",
"name": "Čidlo teploty kotle/Boiler temperature sensor",
"sensorid": "28-0517c3e331ff",
"timer": "0.05",
"x": 190,
"y": 640,
"b077c631bd89e04e",
"a302bf45a6e5141b"
"id": "df5eb5ef00b8a9b4",
"type": "InvertUltimate",
"name": "Změna kontaktu pro relé",
"x": 1550,
"y": 100,
"4350539b6b93cbd6"
"id": "a60573858b081aa7",
"type": "inject",
"props": [
"p": "payload",
"v": "stop",
"vt": "str"
"p": "topic",
"v": "",
"vt": "string"
"repeat": "",
"crontab": "",
"once": false,
"onceDelay": 0.1,
"topic": "",
"payload": "stop",
"payloadType": "str",
"x": 590,
"y": 400,
"521283247438de7a"
"id": "35d9917e01e38f2b",
"type": "trigger",
"name": "Doba prodlevy/Break",
"op1": "true",
"op2": "0",
"op1type": "bool",
"op2type": "str",
"duration": "-10",
"extend": false,
"overrideDelay": false,
"units": "s",
"reset": "stop",
"bytopic": "all",
"topic": "topic",
"outputs": 1,
"x": 1020,
"y": 100,
"916d3525dda0c034"
"id": "916d3525dda0c034",
"type": "trigger",
"name": "Doba podávání paliva/Dosage",
"op1": "true",
"op2": "false",
"op1type": "bool",
"op2type": "bool",
"duration": "2",
"extend": false,
"units": "s",
"reset": "",
"bytopic": "all",
"topic": "topic",
"outputs": 1,
"x": 1270,
"y": 100,
"df5eb5ef00b8a9b4"
"id": "521283247438de7a",
"type": "ui_button",
"group": "974654fbb326da37",
"order": 1,
"width": 0,
"height": 0,
"passthru": true,
"label": "Vypni automatiku natápění/Turn of the heating",
"tooltip": "",
"color": "",
"bgcolor": "",
"icon": "",
"payload": "stop",
"topic": "topic",
"topicType": "msg",
"x": 880,
"y": 400,
"35d9917e01e38f2b",
"fb38939d80faf48e"
"id": "e929974c20ac1b78",
"type": "change",
"rules": [
"t": "change",
"p": "payload",
"pt": "msg",
"from": "true",
"fromt": "bool",
"to": "start",
"tot": "str"
"t": "change",
"p": "payload",
"pt": "msg",
"from": "false",
"fromt": "bool",
"to": "stop",
"tot": "str"
"action": "",
"property": "",
"from": "",
"to": "",
"reg": false,
"x": 740,
"y": 100,
"35d9917e01e38f2b",
"fb38939d80faf48e"
"id": "290b4f4d67ae2e65",
"x": 1550,
"y": 160,
"333641bba4bebedc"
"id": "333641bba4bebedc",
"name": "Relé ventilátoru/Relay Ventilator",
"pin": "10",
"set": false,
"level": "1",
"freq": "",
"out": "out",
"x": 1830,
"y": 160,
"id": "fb38939d80faf48e",
"type": "change",
"rules": [
"t": "change",
"p": "payload",
"pt": "msg",
"from": "start",
"fromt": "str",
"to": "true",
"tot": "bool"
"t": "change",
"p": "payload",
"pt": "msg",
"from": "stop",
"fromt": "str",
"to": "false",
"tot": "bool"
"action": "",
"property": "",
"from": "",
"to": "",
"reg": false,
"x": 740,
"y": 160,
"290b4f4d67ae2e65"
"id": "0047be7bbce7eaff",
"type": "stoptimer",
"duration": "90",
"units": "Minute",
"payloadtype": "bool",
"payloadval": "false",
"x": 520,
"y": 260,
"e929974c20ac1b78"
"id": "ebe0e03ff8858218",
"type": "change",
"rules": [
"t": "change",
"p": "payload",
"pt": "msg",
"from": "true",
"fromt": "bool",
"to": "false",
"tot": "bool"
"action": "",
"property": "",
"from": "",
"to": "",
"reg": false,
"x": 460,
"y": 180,
"0047be7bbce7eaff"
"id": "0516901398016f3e",
"type": "ui_switch",
"label": "Podavač/Feeder",
"tooltip": "",
"order": 4,
"width": 0,
"height": 0,
"passthru": true,
"decouple": "false",
"topic": "topic",
"topicType": "msg",
"style": "",
"onvalue": "true",
"onvalueType": "bool",
"onicon": "",
"oncolor": "",
"offvalue": "false",
"offvalueType": "bool",
"officon": "",
"offcolor": "",
"animate": false,
"x": 1100,
"y": 220,
"2d8e72e9d380f4f0",
"df5eb5ef00b8a9b4"
"id": "196e3fa9b26aac46",
"duration": "10",
"units": "Minute",
"x": 1580,
"y": 300,
"df5eb5ef00b8a9b4"
"id": "2d8e72e9d380f4f0",
"type": "change",
"rules": [
"t": "change",
"p": "payload",
"pt": "msg",
"from": "true",
"fromt": "bool",
"to": "false",
"tot": "bool"
"action": "",
"property": "",
"from": "",
"to": "",
"reg": false,
"x": 1340,
"y": 220,
"196e3fa9b26aac46"
"id": "4e852872cdebdb82",
"label": "Ventilátor",
"tooltip": "",
"order": 4,
"width": 0,
"height": 0,
"passthru": true,
"topic": "topic",
"topicType": "msg",
"style": "",
"onvalue": "true",
"onicon": "",
"oncolor": "",
"officon": "",
"offcolor": "",
"animate": false,
"x": 1100,
"y": 480,
"6211f3087a9c28e0",
"290b4f4d67ae2e65"
"id": "6211f3087a9c28e0",
"type": "change",
"rules": [
"t": "change",
"p": "payload",
"pt": "msg",
"from": "true",
"fromt": "bool",
"to": "false",
"tot": "bool"
"action": "",
"property": "",
"from": "",
"to": "",
"reg": false,
"x": 1360,
"y": 480,
"7a0f60b0bf8bba8f"
"id": "7a0f60b0bf8bba8f",
"duration": "60",
"units": "Minute",
"x": 1600,
"y": 560,
"290b4f4d67ae2e65"
"id": "c536feb68dba4061",
"name": "Napájení relé - havarijní kontakt/Emergency contact",
"pin": "12",
"set": false,
"level": "0",
"freq": "",
"out": "out",
"x": 1650,
"y": 640,
"id": "14654768d599b3b3",
"type": "inject",
"name": "start",
"props": [
"p": "payload"
"repeat": "",
"crontab": "",
"once": false,
"onceDelay": 0.1,
"topic": "",
"payload": "false",
"payloadType": "bool",
"x": 1310,
"y": 700,
"c536feb68dba4061"
"id": "af0c72dffdf6412a",
"type": "inject",
"name": "stop",
"props": [
"p": "payload"
"repeat": "",
"crontab": "",
"once": false,
"onceDelay": 0.1,
"topic": "",
"payload": "true",
"x": 1310,
"y": 760,
"c536feb68dba4061"
"id": "044f23eac72d018c",
"type": "trigger",
"op1": "true",
"op2": "0",
"op1type": "bool",
"op2type": "str",
"duration": "0",
"extend": false,
"units": "ms",
"reset": "reset",
"bytopic": "all",
"topic": "topic",
"outputs": 1,
"x": 880,
"y": 560,
"c536feb68dba4061"
"id": "a302bf45a6e5141b",
"type": "switch",
"name": "Přehřátí kotle/Overheating",
"property": "payload",
"propertyType": "msg",
"rules": [
"t": "gt",
"v": "85",
"vt": "num"
"t": "lt",
"v": "85",
"vt": "num"
"checkall": "true",
"repair": false,
"outputs": 2,
"x": 530,
"y": 640,
"044f23eac72d018c"
"03827abe1b60b473"
"id": "e4df933c04f427cb",
"type": "inject",
"name": "Kvitace poruchy/Fault unblocking",
"props": [
"p": "payload"
"repeat": "",
"crontab": "",
"once": false,
"onceDelay": 0.1,
"topic": "",
"payload": "reset",
"x": 730,
"y": 800,
"7d788da5efb5e944"
"id": "03827abe1b60b473",
"type": "trigger",
"op1": "false",
"op2": "0",
"op1type": "bool",
"op2type": "str",
"duration": "0",
"extend": false,
"units": "ms",
"reset": "reset",
"bytopic": "all",
"topic": "topic",
"outputs": 1,
"x": 880,
"y": 600,
"c536feb68dba4061"
"id": "7d788da5efb5e944",
"order": 4,
"width": 0,
"height": 0,
"passthru": true,
"label": "Kvitace poruchy/Fault unblocking",
"tooltip": "",
"color": "",
"bgcolor": "",
"icon": "",
"payload": "reset",
"topic": "topic",
"topicType": "msg",
"x": 750,
"y": 740,
"044f23eac72d018c",
"03827abe1b60b473",
"cb0f5815f2c64219",
"88844cb6c9b51655"
"id": "514fc7546c998d8b",
"order": 1,
"width": 0,
"height": 0,
"passthru": true,
"label": "Zapni automatiku natápění/Turn on the heating",
"tooltip": "",
"color": "",
"bgcolor": "",
"icon": "",
"payload": "80",
"payloadType": "num",
"topic": "topic",
"topicType": "msg",
"x": 880,
"y": 340,
"b077c631bd89e04e"
"id": "824284c5b3dab0f9",
"type": "inject",
"props": [
"p": "payload"
"p": "topic",
"vt": "str"
"repeat": "",
"crontab": "",
"once": false,
"onceDelay": 0.1,
"topic": "",
"payload": "start",
"x": 590,
"y": 340,
"514fc7546c998d8b"
"id": "cb0f5815f2c64219",
"type": "change",
"rules": [
"t": "change",
"p": "payload",
"pt": "msg",
"from": "reset",
"fromt": "str",
"to": "false",
"tot": "bool"
"action": "",
"property": "",
"from": "",
"to": "",
"reg": false,
"x": 320,
"y": 320,
"0047be7bbce7eaff"
"id": "88844cb6c9b51655",
"type": "change",
"rules": [
"t": "change",
"p": "payload",
"pt": "msg",
"from": "reset",
"fromt": "str",
"to": "60",
"tot": "num"
"action": "",
"property": "",
"from": "",
"to": "",
"reg": false,
"x": 260,
"y": 240,
"b077c631bd89e04e"
"id": "a84115951bcdb11a",
"type": "ui_numeric",
"label": "I want to enter hop values",
"tooltip": "",
"order": 14,
"width": 0,
"height": 0,
"wrap": false,
"passthru": true,
"topic": "topic",
"topicType": "msg",
"format": "{{value}}",
"min": 0,
"max": 10,
"step": 1,
"x": 170,
"y": 820,
"0047be7bbce7eaff"
"id": "78e4ce139b16548c",
"tooltip": "",
"order": 14,
"width": 0,
"height": 0,
"wrap": false,
"passthru": true,
"topic": "topic",
"topicType": "msg",
"min": 0,
"max": 10,
"step": 1,
"x": 170,
"y": 860,
"35d9917e01e38f2b"
"id": "5704c74bbe2a5b2e",
"tooltip": "",
"order": 14,
"width": 0,
"height": 0,
"wrap": false,
"passthru": true,
"topic": "topic",
"topicType": "msg",
"min": 0,
"max": 10,
"step": 1,
"x": 170,
"y": 900,
"916d3525dda0c034"
"id": "b8634c4186422cd0",
"tooltip": "",
"order": 14,
"width": 0,
"height": 0,
"wrap": false,
"passthru": true,
"topic": "topic",
"topicType": "msg",
"min": 0,
"max": 10,
"step": 1,
"x": 170,
"y": 940,
"196e3fa9b26aac46"
"id": "7314c6f59df1fcaa",
"tooltip": "",
"order": 14,
"width": 0,
"height": 0,
"wrap": false,
"passthru": true,
"topic": "topic",
"topicType": "msg",
"min": 0,
"max": 10,
"step": 1,
"x": 170,
"y": 980,
"7a0f60b0bf8bba8f"
"id": "d36edbf595a507d4",
"tooltip": "",
"order": 14,
"width": 0,
"height": 0,
"wrap": false,
"passthru": true,
"topic": "topic",
"topicType": "msg",
"min": 0,
"max": 10,
"step": 1,
"x": 170,
"y": 780,
"b077c631bd89e04e"
"id": "974654fbb326da37",
"type": "ui_group",
"name": "Automatika kotle",
"tab": "069938bb8842257a",
"order": 1,
"disp": true,
"width": "6",
"collapse": false
"id": "069938bb8842257a",
"type": "ui_tab",
"icon": "dashboard",
"disabled": false,
"hidden": false
