Hi! I need a dashboard number cycler, exactly like the UI_numeric node; running into the following issue. The node needs to send a default value (1) whenever its input is triggered in the flow - so I have switch node with that value. The problem is that it doesn't send anything if its already on the value that it's receiving. Is there any workaround ?
Can you provide a small sample flow showing the issue? Please export it and paste it into a response
If it always sends the same value can you just add a wire around the ui_ numeric node ?
Here you go. If numeric node is at value "1" it doesn't pass the msg through. Also, noticed that at certain states (can't confirm which) and sent out a text string "change" instead of number.
"id": "7923d80d937bc1b1",
"type": "tab",
"label": "Flow 1",
"disabled": false,
"info": "",
"env": []
"id": "801a23eb0bcbbaac",
"type": "inject",
"z": "7923d80d937bc1b1",
"props": [
"p": "payload"
"p": "topic",
"vt": "str"
"repeat": "",
"crontab": "",
"once": false,
"onceDelay": 0.1,
"topic": "",
"payload": "",
"payloadType": "date",
"x": 600,
"y": 360,
"98ac5a1eb9f1ed54"
"id": "98ac5a1eb9f1ed54",
"type": "change",
"name": "page",
"rules": [
"t": "set",
"p": "payload",
"pt": "msg",
"to": "1",
"tot": "str"
"t": "set",
"p": "topic",
"pt": "msg",
"to": "topic",
"tot": "str"
"action": "",
"property": "",
"from": "",
"to": "",
"reg": false,
"x": 750,
"y": 360,
"5178c49d1cb0e2ce"
"id": "5178c49d1cb0e2ce",
"type": "ui_numeric",
"label": "",
"tooltip": "",
"group": "20d55a3df46c721c",
"order": 5,
"width": "1",
"height": "1",
"wrap": false,
"passthru": true,
"topic": "topic",
"topicType": "msg",
"format": "{{msg.payload}}",
"min": "0",
"max": "20",
"step": 1,
"className": "",
"x": 890,
"y": 360,
"id": "20d55a3df46c721c",
"type": "ui_group",
"name": "CENTER",
"tab": "5e2e41aa.9826b",
"order": 1,
"disp": false,
"width": "16",
"collapse": false,
"className": ""
"id": "5e2e41aa.9826b",
"type": "ui_tab",
"name": "ANALYTICS",
"icon": "dashboard",
"disabled": false,
"hidden": false
I actually want it to send out (pass through) the same value "1" whenever its triggered in the flow
That's what @dceejay was suggesting.
I notice that your change node sends in a string "1" this should really be a number, so I modified the change node. Try this and see if it does what you need ....
[{"id":"801a23eb0bcbbaac","type":"inject","z":"7923d80d937bc1b1","name":"","props":[{"p":"payload"},{"p":"topic","vt":"str"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","payload":"","payloadType":"date","x":600,"y":360,"wires":[["98ac5a1eb9f1ed54"]]},{"id":"98ac5a1eb9f1ed54","type":"change","z":"7923d80d937bc1b1","name":"page","rules":[{"t":"set","p":"payload","pt":"msg","to":"1","tot":"num"},{"t":"set","p":"topic","pt":"msg","to":"topic","tot":"str"}],"action":"","property":"","from":"","to":"","reg":false,"x":750,"y":360,"wires":[["5178c49d1cb0e2ce","d0c3aa72e0b149d3"]]},{"id":"5178c49d1cb0e2ce","type":"ui_numeric","z":"7923d80d937bc1b1","name":"","label":"","tooltip":"","group":"20d55a3df46c721c","order":5,"width":"1","height":"1","wrap":false,"passthru":true,"topic":"topic","topicType":"msg","format":"{{msg.payload}}","min":"0","max":"20","step":1,"className":"","x":900,"y":300,"wires":[["d0c3aa72e0b149d3"]]},{"id":"d0c3aa72e0b149d3","type":"debug","z":"7923d80d937bc1b1","name":"debug 61","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"false","statusVal":"","statusType":"auto","x":1100,"y":360,"wires":[]},{"id":"20d55a3df46c721c","type":"ui_group","name":"CENTER","tab":"5e2e41aa.9826b","order":1,"disp":false,"width":"16","collapse":false,"className":""},{"id":"5e2e41aa.9826b","type":"ui_tab","name":"ANALYTICS","icon":"dashboard","disabled":false,"hidden":false}]
Thanks, but unfortunately the issue remains. After the numeric node gets set to 1 it no longer passes that same msg through.
Did you try the flow ?
Each time you inject 1 you will see 1 in the debug node, that is what you asked for ?
The numeric node doesn't need to send anything as the wire bypasses it.
I see, yes, that works, just need to disable msg passthrough otherwise you get duplicates if the node is not on 1 - thank you!
