Ui_numeric, how block automatic send payload?
is possible, for ui_numeric send payload only when a press a ui_button?
thanks for help
is write: "Setting msg.enabled to false will disable the widget putput."
is this? how i can do? :slight_smile:
One way is to use a ui form node containing a numeric field. Otherwise this thread is currently discussing solutions for basically the same problem.
https://discourse.nodered.org/t/need-help-to-insert-update-and-delete-data-from-node-red-dashboard-inputs-to-the-database
