so guys I have my custom website, where I have microsoft authentication (via azure ad) and I am using node-red to send requests to file maker, but I need to check before node-red communicates to file maker that the one who sends request is my user, in short I am passing access token to request and I want to check if it's valid in node-red until it will communicate to file maker, so is there any way to connect node-red to azure ad or to solve my problem?
Is this post any different from your previous post?
yes its a little bit different, also your hint didn't help because I couldn't find any helpful flows
So you still have the exact same issue that you raised in the previous post?
