hello guys, I am trying to connect(authorization) to azure ad directly from node red, but I can't figure out how to make it, I have seen some examples that use express.js but I need authentication to be done directly from node-red flow, can any1 help me with example, or any related tutorial/code which will help me (purpose is that I need to check the if the client who uses node-red http in request to connect file maker data api, is a member of my azure ad)
did you search the flows library?
hint: Library - Node-RED
Continued here: Connecting to azure ad with node-red
@mebsn please don't double post. People will reply if/when they can help.
