Hi, im new in node-red. Im trying to set up a connection between telegram bot and node-red.
Can you tell me, who initialize connection, between telegram bot and node telegram receiver.
You need an API key from Telegram. Then you initialise the bot in Telegram using "botfather". Then you can connect from Node-RED to Telegram, you will see the bot as a "user" in your list of contacts. You can then choose whether to allow the bot to join some groups.
Thanks for your replay.
