"Connection lost" on a specific dashboard tab
I currently have three dashboard tabs.
One of them draws a chart with 4 lines using data from MySQL.
When I switch to this tab using the dashboard hamburger menu:
  • A mesage pops up "Connection lost" for a second.
  • Same message once more.
  • ~ 5sec delay.
  • The graph is displayed.
I'm struggling to identify the cause.
It seems not to be a problem in the SQL query or drawing the graph. If I add a button to repeat the query it redraws the graph instantly.
The graph has 4 lins, each with about 40 points.
Every time I deploy this flow the Mysql node status is "not yet connected" & I get this error on the node-red-dashboard node (ui_base)
A snippet of the Node-red log:
6 Dec 17:26:40 - [info] Starting flows
6 Dec 17:26:40 - [error] [ui_base:70ea48b6c7ce5aec] TypeError: Cannot read properties of undefined (reading 'replace')
6 Dec 17:26:40 - [info] [cronplus:8ee84f7bf63b1027] createTask - [truncated irrelevant]
6 Dec 17:26:40 - [info] Started flows
6 Dec 17:26:40 - [error] [mysql:b558a28a8cbd9b7e] Database not connected
6 Dec 17:26:40 - [info] [mqtt-broker:754230cc.99c44] Connected to broker: mqtt://localhost:1883
Can anyone suggest where to look for the cause?
Because your inject node will inject immediately after deploy before the mysql node is actually connected ?
Yes, that probably explains that, so it's not a symptom of the actual problem.
