Hello
I am new to the party...
My question is : Can i control a Light with Node RED which is connected in the Google Home app ?
I found much stuff about controlling lights in Google Home which are connected in the Node RED, but nothing in the other direction.
Thx in advance
Flixm
18 March 2022 22:37
2
Normally you're controlling the light direct and not over google home.
What kind of light do you want to control?
No, Google do not offer any API that would let you do this
My workaround for Alexa is to use a Pi to speak to a spare Alexa device
Same approach should work for Google Home setups I'd thought
https://simplesi.net/control-any-alexa-device-using-node-red/
Not sure if you know about the 'textCommand' in the Alexa Routine node ?
inject what you would otherwise say as plain text, and Alexa will do it
I didn't until recently but unfortunately (like all of these Alexa/Google home things) it has issues.
At the moment, I am using an old Pi to convert text to speech and I've wired the output of it to headphones and glued headphone earpiece next to mic input on a cheap Alexa Flex
All works well
But when I saw about this text command - I thought - I'll be able to send my desired command direct to the Flex
But (as with everything to do with this sort of thing) it doesn't work for the thing I want it work for
i.e
If I say tell my pi to say "Alexa, ask cheerlights to change to colo…
Actually getting a Pi to speak a command has been working very reliably
Except if loud background noise when speaking of course
I Must get round to putting it in the cupboard under the stairs
Make a small anechoic chamber with egg boxes
Thx for all ideas.
I saw a way with smart home i will try it!
@DeWoAlliSeged7 - Could you explain in a little more detail what you are trying to achieve, giving an example would help.
Also, what are you using to switch the lighting... A Shelly, sonoff or something else?
I successfully control lighting using either voice commands or by commands issued by node-RED flows, using node-red-contrib-google-smarthome
I have a switch named Elesion: Luminea Home Control Lichtschalter: 4er-Set WLAN-Lichttaster, App, komp. zu Siri, Alexa, Google Assistant (Smart Home Lichtschalter)
The switch is connected with the Elesion App and with Google Home.
I would like to controle the switch with a node red command.
There isn't a lot of information in the link, but it does say "Also relevant or suitable for: TUYA", so if it is, you could;
disable the google home connection to the switch
send/receive switch commands from/to your node-RED flow using node-red-contrib-tuya-smart-device
install node-red-contrib-google-smarthome and also build that into your node-RED flow to handle voice commands
Then you could control the switch by voice using google smarthome > tuya node > switch and programmatically by node-RED > tuya node > switch
Thx i can connect!
I have to figure out how to turn it on and off but i connected! THX!
