ControlLogix to MySQL
The following flow is how we move our data from an Allen Bradley ControlLogix PLC to mySQL. Every time the tag for the PCCC node changes state, based off a counter in the PLC, we trigger a set of IgnitionReads. The data from the reads are parsed individually and strung together into an array of objects. They are then sorted into a consistent order (for troubleshooting purposes and clarity), parsed to their appropriate mySQL column names (again, for troubleshooting and clarity), and pushed to mySQL.
We are new to node-red and ignition, so anyone's input on a better way to make our flows and programs is welcome and encouraged to share your thoughts!
[{"id":"c932d11b.508f3","type":"ignition-tag-read","z":"e2d07ac5.b0d02","server":"45e2d8ce.d2f238","value":"","valueType":"msg.payload","tagPath":"Edge Nodes/Groov/Morton/Mill/DomoTest/Domo/ElapsedShiftTime","name":"ElapsedShiftTime","x":510,"y":157,"wires":[["c89bd3ee.d222f"]]},{"id":"a4b5859a.abcc","type":"pccc in","z":"e2d07ac5.b0d02","endpoint":"","mode":"single","variable":"N76","diff":true,"name":"","x":247,"y":338,"wires":[["68486d6e.8f3aac"]]},{"id":"8b8a1c95.258198","type":"ignition-tag-read","z":"e2d07ac5.b0d02","server":"45e2d8ce.d2f238","value":"","valueType":"msg.payload","tagPath":"Edge Nodes/Groov/Morton/Mill/DomoTest/Domo/FillPercent","name":"FillPercent","x":490,"y":190,"wires":[["e1b866f8.aa1758"]]},{"id":"19c9bdc.222fe42","type":"ignition-tag-read","z":"e2d07ac5.b0d02","server":"45e2d8ce.d2f238","value":"","valueType":"msg.payload","tagPath":"Edge Nodes/Groov/Morton/Mill/DomoTest/Domo/AverageFeedSpeed","name":"AverageFeedSpeed","x":522,"y":222,"wires":[["2100870a.e9e288"]]},{"id":"2d1166f4.ddbee2","type":"ignition-tag-read","z":"e2d07ac5.b0d02","server":"45e2d8ce.d2f238","value":"","valueType":"msg.payload","tagPath":"Edge Nodes/Groov/Morton/Mill/DomoTest/Domo/AverageTransferSpeed","name":"AverageTransferSpeed","x":532,"y":255,"wires":[["c3306738.144f68"]]},{"id":"36dff0ec.aefed","type":"ignition-tag-read","z":"e2d07ac5.b0d02","server":"45e2d8ce.d2f238","value":"","valueType":"msg.payload","tagPath":"Edge Nodes/Groov/Morton/Mill/DomoTest/Domo/MaximumSpeed","name":"MaximumSpeed","x":502,"y":288,"wires":[["28276ccb.206ba4"]]},{"id":"81b76704.7903","type":"ignition-tag-read","z":"e2d07ac5.b0d02","server":"45e2d8ce.d2f238","value":"","valueType":"msg.payload","tagPath":"Edge Nodes/Groov/Morton/Mill/DomoTest/Domo/TimeRunningReady","name":"TimeRunningReady","x":522,"y":320,"wires":[["f7fba382.8bd988"]]},{"id":"e143cd36.2e9638","type":"ignition-tag-read","z":"e2d07ac5.b0d02","server":"45e2d8ce.d2f238","value":"","valueType":"msg.payload","tagPath":"Edge Nodes/Groov/Morton/Mill/DomoTest/Domo/TimeRunningEmpty","name":"TimeRunningEmpty","x":512,"y":354,"wires":[["6861c7d5.bf121"]]},{"id":"dd52dcc7.d9bce8","type":"ignition-tag-read","z":"e2d07ac5.b0d02","server":"45e2d8ce.d2f238","value":"","valueType":"msg.payload","tagPath":"Edge Nodes/Groov/Morton/Mill/DomoTest/Domo/PieceCount","name":"PieceCount","x":495,"y":386,"wires":[["b3e8bbd9.c4dbe"]]},{"id":"982f1d67.53abc","type":"ignition-tag-read","z":"e2d07ac5.b0d02","server":"45e2d8ce.d2f238","value":"","valueType":"msg.payload","tagPath":"Edge Nodes/Groov/Morton/Mill/DomoTest/Domo/VolIn","name":"VolIn","x":475,"y":417,"wires":[["36eeee85.459f6a"]]},{"id":"47cf29c4.4d8998","type":"ignition-tag-read","z":"e2d07ac5.b0d02","server":"45e2d8ce.d2f238","value":"","valueType":"msg.payload","tagPath":"Edge Nodes/Groov/Morton/Mill/DomoTest/Domo/VolOut","name":"VolOut","x":475,"y":448,"wires":[["6c343e7c.cc7d18"]]},{"id":"5f48a717.5e4f7","type":"ignition-tag-read","z":"e2d07ac5.b0d02","server":"45e2d8ce.d2f238","value":"","valueType":"msg.payload","tagPath":"Edge Nodes/Groov/Morton/Mill/DomoTest/Domo/StopOperatorFrequency","name":"StopOperatorFrequency","x":533,"y":478,"wires":[["f5788bda.b2bfd"]]},{"id":"77423292.fc9974","type":"ignition-tag-read","z":"e2d07ac5.b0d02","server":"45e2d8ce.d2f238","value":"","valueType":"msg.payload","tagPath":"Edge Nodes/Groov/Morton/Mill/DomoTest/Domo/StopOperatorDuration","name":"StopOperatorDuration","x":521,"y":509,"wires":[["5d9a6bd4.5e7e64"]]},{"id":"aad4946e.092718","type":"ignition-tag-read","z":"e2d07ac5.b0d02","server":"45e2d8ce.d2f238","value":"","valueType":"msg.payload","tagPath":"Edge Nodes/Groov/Morton/Mill/DomoTest/Domo/StopAlignmentFrequency","name":"StopAlignmentFrequency","x":528,"y":541,"wires":[["bbcf3fa6.997a4"]]},{"id":"fd89467e.176828","type":"ignition-tag-read","z":"e2d07ac5.b0d02","server":"45e2d8ce.d2f238","value":"","valueType":"msg.payload","tagPath":"Edge Nodes/Groov/Morton/Mill/DomoTest/Domo/StopAlignmentDuration","name":"StopAlignmentDuration","x":527,"y":574,"wires":[["f973c1a7.e01138"]]},{"id":"86fccabb.610478","type":"ignition-tag-read","z":"e2d07ac5.b0d02","server":"45e2d8ce.d2f238","value":"","valueType":"msg.payload","tagPath":"Edge Nodes/Groov/Morton/Mill/DomoTest/Domo/StopOverDimFrequency","name":"StopOverDimFrequency","x":526,"y":607,"wires":[["69c6f3ed.bd76f4"]]},{"id":"4960c9bf.719ea8","type":"ignition-tag-read","z":"e2d07ac5.b0d02","server":"45e2d8ce.d2f238","value":"","valueType":"msg.payload","tagPath":"Edge Nodes/Groov/Morton/Mill/DomoTest/Domo/StopOverDimDuration","name":"StopOverDimDuration","x":515,"y":641,"wires":[["bdbe0df2.3c532"]]},{"id":"a3c5f14d.d433b8","type":"ignition-tag-read","z":"e2d07ac5.b0d02","server":"45e2d8ce.d2f238","value":"","valueType":"msg.payload","tagPath":"Edge Nodes/Groov/Morton/Mill/DomoTest/DomoIndex","name":"DomoIndex","x":490,"y":124,"wires":[["ae2c5d8c.e1c67"]]},{"id":"faca6252.c7f648","type":"function","z":"e2d07ac5.b0d02","name":"Parse Data","func":"return {\n mcId : msg.DomoIndex,\n elapsedShift : msg.ElapsedShiftTime,\n fp : msg.FillPercent,\n avgfeedspeed : msg.AverageFeedSpeed,\n avgtransferspeed : msg.AverageTransferSpeed,\n maxspeed : msg.MaximumSpeed,\n timerunning : msg.TimeRunningReady,\n timerunningempty : msg.TimeRunningEmpty,\n piececount : msg.PieceCount,\n rawvol : msg.VolIn,\n finishedvol : msg.VolOut,\n stopopfreq : msg.StopOperatorFrequency,\n stopopdur : msg.StopOperatorDuration,\n stopalignfreq : msg.StopAlignmentFrequency,\n stopalignndur : msg.StopAlignmentDuration,\n stopdimfreq : msg.StopOverDimFrequency,\n stopdimdur : msg.StopOverDimDuration,\n}","outputs":1,"noerr":0,"x":1049,"y":479,"wires":[["205a58a9.8c3f78"]]},{"id":"ae2c5d8c.e1c67","type":"function","z":"e2d07ac5.b0d02","name":"Parse Data","func":"return{\n DomoIndex : msg.payload.ignitionResult.value,\n\n}","outputs":1,"noerr":0,"x":739,"y":124,"wires":[["dc7c04f9.b09ec8"]]},{"id":"c89bd3ee.d222f","type":"function","z":"e2d07ac5.b0d02","name":"Parse Data","func":"return{\n ElapsedShiftTime : msg.payload.ignitionResult.value,\n\n}","outputs":1,"noerr":0,"x":738,"y":157,"wires":[["dc7c04f9.b09ec8"]]},{"id":"e1b866f8.aa1758","type":"function","z":"e2d07ac5.b0d02","name":"Parse Data","func":"return{\n FillPercent : msg.payload.ignitionResult.value,\n\n}","outputs":1,"noerr":0,"x":738,"y":190,"wires":[["dc7c04f9.b09ec8"]]},{"id":"2100870a.e9e288","type":"function","z":"e2d07ac5.b0d02","name":"Parse Data","func":"return{\n AverageFeedSpeed : msg.payload.ignitionResult.value,\n\n}","outputs":1,"noerr":0,"x":739,"y":222,"wires":[["dc7c04f9.b09ec8"]]},{"id":"c3306738.144f68","type":"function","z":"e2d07ac5.b0d02","name":"Parse Data","func":"return{\n AverageTransferSpeed : msg.payload.ignitionResult.value,\n\n}","outputs":1,"noerr":0,"x":739,"y":255,"wires":[["dc7c04f9.b09ec8"]]},{"id":"28276ccb.206ba4","type":"function","z":"e2d07ac5.b0d02","name":"Parse Data","func":"return{\n MaximumSpeed : msg.payload.ignitionResult.value,\n\n}","outputs":1,"noerr":0,"x":739,"y":288,"wires":[["dc7c04f9.b09ec8"]]},{"id":"f7fba382.8bd988","type":"function","z":"e2d07ac5.b0d02","name":"Parse Data","func":"return{\n TimeRunningReady : msg.payload.ignitionResult.value,\n\n}","outputs":1,"noerr":0,"x":739,"y":320,"wires":[["dc7c04f9.b09ec8"]]},{"id":"6861c7d5.bf121","type":"function","z":"e2d07ac5.b0d02","name":"Parse Data","func":"return{\n TimeRunningEmpty : msg.payload.ignitionResult.value,\n\n}","outputs":1,"noerr":0,"x":738,"y":354,"wires":[["dc7c04f9.b09ec8"]]},{"id":"b3e8bbd9.c4dbe","type":"function","z":"e2d07ac5.b0d02","name":"Parse Data","func":"return{\n PieceCount : msg.payload.ignitionResult.value,\n\n}","outputs":1,"noerr":0,"x":738,"y":386,"wires":[["dc7c04f9.b09ec8"]]},{"id":"36eeee85.459f6a","type":"function","z":"e2d07ac5.b0d02","name":"Parse Data","func":"return{\n VolIn : msg.payload.ignitionResult.value,\n\n}","outputs":1,"noerr":0,"x":737,"y":416,"wires":[["dc7c04f9.b09ec8"]]},{"id":"6c343e7c.cc7d18","type":"function","z":"e2d07ac5.b0d02","name":"Parse Data","func":"return{\n VolOut : msg.payload.ignitionResult.value,\n\n}","outputs":1,"noerr":0,"x":738,"y":447,"wires":[["dc7c04f9.b09ec8"]]},{"id":"f5788bda.b2bfd","type":"function","z":"e2d07ac5.b0d02","name":"Parse Data","func":"return{\n StopOperatorFrequency : msg.payload.ignitionResult.value,\n\n}","outputs":1,"noerr":0,"x":738,"y":478,"wires":[["dc7c04f9.b09ec8"]]},{"id":"5d9a6bd4.5e7e64","type":"function","z":"e2d07ac5.b0d02","name":"Parse Data","func":"return{\n StopOperatorDuration : msg.payload.ignitionResult.value,\n\n}","outputs":1,"noerr":0,"x":737,"y":509,"wires":[["dc7c04f9.b09ec8"]]},{"id":"bbcf3fa6.997a4","type":"function","z":"e2d07ac5.b0d02","name":"Parse Data","func":"return{\n StopAlignmentFrequency : msg.payload.ignitionResult.value,\n\n}","outputs":1,"noerr":0,"x":737,"y":541,"wires":[["dc7c04f9.b09ec8"]]},{"id":"f973c1a7.e01138","type":"function","z":"e2d07ac5.b0d02","name":"Parse Data","func":"return{\n StopAlignmentDuration : msg.payload.ignitionResult.value,\n\n}","outputs":1,"noerr":0,"x":736,"y":574,"wires":[["dc7c04f9.b09ec8"]]},{"id":"69c6f3ed.bd76f4","type":"function","z":"e2d07ac5.b0d02","name":"Parse Data","func":"return{\n StopOverDimFrequency : msg.payload.ignitionResult.value,\n\n}","outputs":1,"noerr":0,"x":736,"y":607,"wires":[["dc7c04f9.b09ec8"]]},{"id":"bdbe0df2.3c532","type":"function","z":"e2d07ac5.b0d02","name":"Parse Data","func":"return{\n StopOverDimDuration : msg.payload.ignitionResult.value,\n\n}","outputs":1,"noerr":0,"x":735,"y":641,"wires":[["dc7c04f9.b09ec8"]]},{"id":"dc7c04f9.b09ec8","type":"join","z":"e2d07ac5.b0d02","name":"","mode":"custom","build":"array","property":"","propertyType":"full","key":"topic","joiner":"\n","joinerType":"str","accumulate":false,"timeout":"","count":"17","reduceRight":false,"reduceExp":"","reduceInit":"","reduceInitType":"","reduceFixup":"","x":1051,"y":386,"wires":[["4032b221.50c834"]]},{"id":"68486d6e.8f3aac","type":"delay","z":"e2d07ac5.b0d02","name":"","pauseType":"delay","timeout":"1000","timeoutUnits":"milliseconds","rate":"1","nbRateUnits":"1","rateUnits":"second","randomFirst":"1","randomLast":"5","randomUnits":"seconds","drop":false,"x":284,"y":395,"wires":[["a3c5f14d.d433b8","c932d11b.508f3","8b8a1c95.258198","19c9bdc.222fe42","2d1166f4.ddbee2","36dff0ec.aefed","81b76704.7903","e143cd36.2e9638","dd52dcc7.d9bce8","982f1d67.53abc","47cf29c4.4d8998","5f48a717.5e4f7","77423292.fc9974","aad4946e.092718","fd89467e.176828","86fccabb.610478","4960c9bf.719ea8"]]},{"id":"4032b221.50c834","type":"function","z":"e2d07ac5.b0d02","name":"Array Sort","func":"payloadArray = msg.payload;\n\nvar resultObject = payloadArray.reduce(function(result, currentObject) {\n for(var key in currentObject) {\n if (currentObject.hasOwnProperty(key)) {\n result[key] = currentObject[key];\n }\n }\n \n return result;\n}, {});\n\n\nreturn resultObject;\n","outputs":1,"noerr":0,"x":1052,"y":430,"wires":[["faca6252.c7f648"]]},{"id":"205a58a9.8c3f78","type":"function","z":"e2d07ac5.b0d02","name":"mySQL Write","func":"msg.topic = "INSERT INTO plctest (mcId, elapsedShift, fp, avgfeedspeed,avgtransferspeed,maxspeed,timerunning,timerunningempty,piececount,rawvol,finishedvol,stopopfreq,stopopdur,stopaligndur,stopdimfreq,stopdimdur) VALUES (?,?,?,?,?,?,?,?,?,?,?,?,?,?,?,?)";\nmsg.payload = [msg.mcId,msg.elapsedShift,msg.fp,msg.avefeedspeed,msg.avetransferspeed,msg.maxspeed,msg.timerunning,msg.timerunningempty,msg.piececount,msg.rawvol,msg.finishedvol,msg.stopopfreq,msg.stopopdur,msg.stopaligndur,msg.stopdimfreq,msg.stopdimdur];\nreturn msg;","outputs":1,"noerr":0,"x":1048,"y":530,"wires":[["cfab0670.ce414"]]},{"id":"cfab0670.ce414","type":"mysql","z":"e2d07ac5.b0d02","mydb":"","name":"","x":1037,"y":586,"wires":[[]]},{"id":"45e2d8ce.d2f238","type":"ignition-server","z":"","hostname":"localhost","port":"8088","ssl":false,"defaultTagProvider":"edge","name":""}]
Why are you using node red to move the data and you already have ignition?
Ignition transaction groups do this exact thing very well. Sounds like node is running middleman work that you could be doing natively with Ignition
