Gawan
1
i am reading several float values from Global and add them up in parameter payload:
var v1 = global.get('V.S.Power')||0;
var v2 = global.get('V.N.Power')||0;
var v3 = global.get('V.O.Power')||0;
msg.payload = v1 + v2 + v3;
To get a nice value for my Dashboard I try to convert the value to an INT:
msg.payload = parseInt(msg.payload);
But no matter what I try, I always get a FLOAT value instead of an INT ... showing dozens of digits behind the coma
What am I doing wrong ?
BR
Gawander
Do you return the msg after setting payload?
Gawan
3
Yes, I return two msg-Objects:
return [msg,msg2];
I pass the msg to a dashboard text Node using {{msg.payload}}
edje11
4
Try .toFixed(0);
msg.payload = parseInt(msg.payload).toFixed(0);
E1cid
5
I suspect you are returning an array to the text display in the dashboard
ie. [7, 12345]
can we see a debug of the function output?
And what is in msg2?
Do you have 2 outputs on the function?
which msg (msg or msg2) is the one going to this dashboard item?
Gawan
8
msg2 is another value but is independent, ignore it
yes, I have 2 outputs, the first one (msg) goes to the dashboard, ignore msg2
Colin
9
Put a debug node on the output going to the ui node and show us what it says.
