Saving a msg.payload value as an integer - Help needed
I have a global value which is an integer. I am passing it to a JOIN node before saving it to an Influxdb, but it appears to be saving as a string. I've sent the data from JOIN into a Debug Node, which shows the JSON data as a string.
I'm using a simple function
msg.payload = global.get("TodayDailyGeneration").toFixed(2);
msg.topic = "solar";
toFixed()
Actually does return a string
you might want to use
msg.payload = parseFloat(global.get("TodayDailyGeneration").toFixed(2));
I think :sweat_smile: - i'm never fully confident with these things
better folk around here, if I'm incorrect.
Ah ha - I had tried parseint, but I see now I should have used parseInt !!!
Second question - related - how would I define the source in a Change node ?
You should use parseFloat if you have precision you need to retain (given you want 2 decimal places) :wink:
As for the change node.
you can set the root path as a dropdown (this can be chosen for both the target property and source property)
Screenshot 2022-12-30 at 22.40.30
or if you mean setting the payload with this formatting via a change node
set the to the value as $round($globalContext("TodayDailyGeneration"),2)
making sure to mark it as JSONata
Screenshot 2022-12-30 at 22.56.19
Thank you so much - really appreciated
