This is my msg.payload Object:
How could i change all string values into integers?
I think a function like this will work...
msg.payload = {"temperature":"35.1", "humidity":"27.3", "location": "Las Vegas"}
for (const key in msg.payload) {
if (parseInt(msg.payload[key])) {
msg.payload[key] = parseInt(msg.payload[key]);
But I see that your example NewATURVendor is almost numeric (Hex?) and you might want to perform parseInt() only on selected fields.
I think that may need to be a bit more sophisticated. If the string value is "0" then the if will fail. Perhaps it should be a NaN test.
Thanks a lot. Here is my complete solution:
msg.measurement = "ZOOMsoft/DSL"
for ( const key in msg.payload ) {
if ( typeof msg.payload[ key ] == "undefined" ) {
msg.payload[ key ] = 0;
node.warn(key);
} else {
if ( parseInt( msg.payload[ key ] ) ) {
msg.payload[ key ] = parseInt( msg.payload[ key ] );
msg.payload = [ msg.payload , { name: "Banu Haus" } ];
after that i send the data to an influxdb
Add two named debug node, showing what is going into the function and what is coming out. What do they show when the write fails?
Period=undefined
That might be the spot where it fails.
