Convert 2 bytes in a buffer to integer
Please inquire about converting numbers.
Here is the buffered value.
[1,3,10,1,4] > msg.payload
Create a new buffer and truncate the item located at [3],[4]
var pay1= Buffer.alloc(2);
pay1[0]=msg.payload[3].slice(0,2)
pay1[0]=msg.payload[4].slice(0,2)
Then slice it again and turn it into a string.
var pay2=pay1.slice(0,4).toString('hex');
Then you get something like this:
"0104"
So we convert this value to a number.
var pay3=Number(pay2);
Then it comes out in numeric form.
It comes out as 104 or 0x68.
the value i want is
It should come out as 0x104, the number 260.
But I keep getting 104 or 0x68.
Is there any way to solve this?
The code is organized as follows.
buffer [1,3,10,1,4]
pay1[0]=msg.payload[3].slice(0,2);
pay1[0]=msg.payload[4].slice(0,2);
msg.payload=pay3;
That's how NodeJS Buffer.toString('hex') works. It's output is a hex string, but without the leading '0x'. By coincidence, your number doesn't contain digits with a to f, so the Number conversions thinks it's a decimal.
If you want to convert a Buffer part into a number, I suggest you use one of the many conversion functions, like readInt16LE([offset]). It's much easier and less error-prone.
See the docs for more methods like that: Buffer | Node.js v14.17.3 Documentation
Alternatively, there's an excellent node with does Buffer conversions for you:
thank you for the reply.
I solved the problem in another way.
I solved it as below.
var pay2=Buffer.alloc(2);
pay2[0]=msg.payload[3];
pay2[1]=msg.payload[4];
var pay3=pay2.slice(0,4).toString('hex');
var pay4=Number("0x"+pay3);
As @kuema suggested, this is far easier with buffer-parser...
[{"id":"8f6091afbdeee1b0","type":"inject","z":"1683bd9a.5e0a02","name":"[1,3,10,1,4]","props":[{"p":"payload"},{"p":"topic","vt":"str"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","payload":"[1,3,10,1,4]","payloadType":"bin","x":770,"y":140,"wires":[["029ef0aab35cc3b7"]]},{"id":"029ef0aab35cc3b7","type":"buffer-parser","z":"1683bd9a.5e0a02","name":"","data":"payload","dataType":"msg","specification":"spec","specificationType":"ui","items":[{"type":"int16be","name":"item1","offset":3,"length":1,"offsetbit":0,"scale":"1","mask":""}],"swap1":"","swap2":"","swap3":"","swap1Type":"swap","swap2Type":"swap","swap3Type":"swap","msgProperty":"payload","msgPropertyType":"str","resultType":"value","resultTypeType":"output","multipleResult":true,"fanOutMultipleResult":false,"setTopic":true,"outputs":1,"x":950,"y":140,"wires":[["24254f481d8d7fbf"]]},{"id":"24254f481d8d7fbf","type":"debug","z":"1683bd9a.5e0a02","name":"","active":true,"tosidebar":true,"console":false,"tostatus":true,"complete":"payload","targetType":"msg","statusVal":"payload","statusType":"auto","x":1120,"y":140,"wires":[]}]
If you insist on DIY then you should probably fix up your function code. There is no need to convert to hex string & append '0x0' and then parse it back to an integer.
Combining bytes to make an integer is as simple as shifting the one byte 8 places left then OR the 2 bytes...
msg.payload = msg.payload[3] << 8 | msg.payload[4];
proof...
It is not possible to do it in the Buffer Node because some modifications have to be made in the function code.
We will refer to it next time.
