Converting MQTT location to GEOFENCE GPS
Hi
My understanding of Java is quite low, however, I would like some help writing a function.
My mqtt device tracker gives this payload:
12/10/2018, 11:47:33 AM[node: 978c90cb.73b7]
zanzito/shared_locations/my_cell : msg.payload : string[148]
{"battery_level":83,"longitude":143.5514104,"latitude":252122.447,"altitude":47.70000076293945,"gps_accuracy":22,"user":"my_cell","tst":1544406310}
I would like to extract the longitude and latitude and rename it to one of these 3 formats
msg.location.lat & msg.location.lon
msg.lat & msg.lon
msg.payload.lat & msg.payload.lon
Thanks in advance.
So what have you tried so far?
I may have just worked it out, not by using a function, however.
This was my function.
msg = {
lat:msg.data.latitude,
lon:msg.data.longitude
That did not work.
I then used the following nodes:
  • JSON node to convert the string
  • Change node with the following rules
    • Set location.lat -> payload.latitude
    • Set location.lon -> payload.longitude
I am sure this could be written as a function, but it works.
The function now will be a mental exercise.
