I need some help.
I have Node-Red running as an instance in ioBroker which is running in a Docker container on my Synology DS.
With the node "write file" I have written some data to a file called TEST.txt.
In Docker terminal
find -name TEST.txt
delivers
/node_modules/iobroker.node-red/TEST.txt
the full path appears to be
/opt/iobroker/node_modules/iobroker.node-red/TEST.txt
In Synology SSH Terminal (as Admin)
sudo docker ps
delivers CONTAINER ID ab6e717f3401 and NAMES buanet-iobroker1
--> Without sudo permission is denied!
Still in Synology SSH Session,
ls
delivers "Drive" (which is a folder in admin's home-folder).
So .... I would like to copy TEST.txt to "Drive".
In Syno SSH:
sudo docker cp ab6e717f3401:/opt/iobroker/node_modules/iobroker.node-red/TEXT.txt /Drive
The command is executed without an error message. But there is no file in Drive.
What am I doing wrong? I am not fluent in terminal-commands. So please .... slowly ![]()
Regards
Dennis
