Hello everybody,
I'm a begginer with Node RED, i started first with a RaspberryPi and now I use Node Red with my Synology DS411+II. (Syno+Docker+NodeRed)
I'm looking for write a file on my Syno.
I give access to /NodeRedFiles and /node-red
In Node Red, everything is ok or work, i can see the image preview but in my Synology i can't show the file in the folder.
Do you have and idea?
Have you thought of trying the same path style as the Synology shows in the interface: forward slashes, rather than backward slashes.
in the nodered/data diretory there is a file called settings.js
did you change the setting so things are written to the filesystem(persistent) instead of to memory
contextStorage: {
default: {
module:"localfilesystem"
i use these settings
to access a file in tts i use this.
you need to use the path relative to the default path.
Thank you, i thing is the good direction, but i don't know where are installed the files?
Do you have a idea?
