Copy more then 500 Byte in debug
Hello
I become an array of around 700 byte from an serial device. It is an array.
When i use an Debug the Message drop in the Debug window and shows it has 700 Byte. When i use the Copy Message Button in the Debug window it copy only 500 Byte
Is this an Bug or an Feature? Is there any way to Copy the full Message ?
Greetings from Germany
Hi Sven
I assume you mean buffer?
Yes, but you will note the 500~700 are not viewable.
It is a feature to prevent the websocket from node-red to browser being overloaded.
In situations like this, if you actually need to inspect 700 individual bytes, it is notmally recommended you write the payload to a file for closer inspection.
NOTE: the data is there (at server-side) it is just not transmitted to the debug (to keep the editor responsive)
Okay thank you.
