Correct json notation?
Hello - very much a NR newbie.
I want to make a HomeBridge compatable light come on when the drive gate opens, but I can't work out what the correct notation is within a change node.
To test things I have created this flow:
I have downloaded and installed the homebridge-magichome-platform plugin for HomeBridge, and have included the following in my config file. What should I put in the change node to trigger the lights? I have tried loads of combinations such as {"On":"false"} etc etc, but none work.
When I have got this test to work, I can bring in a feed from the gate.
TIA
https://github.com/sahilchaddha/homebridge-magichome-platform#readme
        "platform": "MagicHome-Platform",
        "debug": true,
        "lights": [
                "name": "Office LEDs",
                "ip": "192.168.2.89",
                "setup": "RGBW",
                "purewhite": false,
                "timeout": 10000
        "presetSwitches": [
                "name": "Gate Open Strobe Flash",
                "ips": {
                    "192.168.2.89": "255,255,255"
                "preset": "seven_color_strobe_flash",
                "speed": 60
Hi .
What node is that orange office LED node? Have you read it's readme in the flow library? When that orange node is selected/highlighted, look in the sidebar info panel to see if it has some built-in help information?
Also, show us the debug output.
Is that meant to be an IP and network mask? If so, the mask should probably be "255.255.255.0"
With it being office lights, it could also be IP address of the device, followed by RGB brightness levels from 0 to FF in hexadecimal. Which in this context makes more sense to me :slight_smile: But obviously I could be wrong too
haha, you can tell that my IT background is coming through as I immediately assumed infrastructure. :grin:
Thanks all - your replies made me look deeper and I now realise that just selecting the "to" dropdown of JSON isn't enough - you also have to type the { & } in the box. Very embarrassing, but at least I now know :stuck_out_tongue_winking_eye:
