Hello, I´m using the node-red dashboard for a cocktailmachine.
First I need to select 10 from 20 ingredients with checkboxes from the form-node. Can I count the selected checkboxes before submitting the values?
Is it also possible with switches from the form-node?
If no, how can I count them after submitting?
Thank´s for helping
Hi Partyarti!
A cocktailmachine sounds awesome! Using the form-node you can't easily count the selected checkboxes before submitting. You'd have to create a ui-template that parses your html and count the md-icons that have been selected.
Counting after submitting is much easier, you could use a function node with the following:
let count = 0
for (let x in msg.payload) {
if (msg.payload[x] === true){
count++
msg.count = count
Another option would be using the split node followed by a switch node (set to: is true) followed by a node-red-contrib-message-counter node.
Cheers!
