I have been asked to create a dashboard to plot the function y=3x+x^2 on a graph. I am really struggling to find anything on line that shows a step by step on how to do this. The stuff I did find seems to skip the details. can anyone help with this? thanks in advance
thank you,
yep I appreciate that genuinely want to learn it properly. the dashboard above is the path that i am trying to go down, but cannot get it to generate the graph. I assume that the function needs to be written in script in the function node? maybe I am getting the syntax wrong. I have also tried the the combi curve node but I'm having a similar issue with input.
correct .. in the function node you have to generate an array for X and Y coordinates by using javascript
read here for the array requirements
