Create a graph from csv with time and 6 columns
Hello All!
I'm trying to create a graph from a CSV file below is the flow I have:
The CSV is very simple, one column with time and 6 columns with data. However, I'm not able to display anything in the graph. What I'm doing wrong? Thank you so much.
CSV sample data:
TIME,IA,IB,IC,VA,VB,VC
09:21.3,-3.984,2.188,1.563,-0.165,0.105,0.057
09:21.3,-3.984,1.406,2.266,-0.169,0.077,0.089
09:21.3,-3.75,0.703,2.734,-0.161,0.045,0.111
        "id": "ececab80965a5f13",
        "type": "tab",
        "label": "graph csv",
        "disabled": false,
        "info": ""
        "id": "5e2714570cd93537",
        "type": "inject",
        "z": "ececab80965a5f13",
        "props": [
                "p": "payload"
                "p": "topic",
                "vt": "str"
        "repeat": "",
        "crontab": "",
        "once": false,
        "onceDelay": 0.1,
        "topic": "start",
        "payload": "1",
        "payloadType": "num",
        "x": 150,
        "y": 80,
                "92d76645c7b27a3a"
        "id": "f62c08cb2bed5705",
        "type": "debug",
        "active": true,
        "tosidebar": true,
        "console": false,
        "tostatus": false,
        "complete": "true",
        "targetType": "full",
        "statusVal": "",
        "statusType": "auto",
        "x": 770,
        "y": 160,
        "id": "92d76645c7b27a3a",
        "type": "file in",
        "filename": "C:\\Users\\user\\Documents\\yesid1.csv",
        "format": "utf8",
        "chunk": false,
        "sendError": false,
        "encoding": "none",
        "allProps": false,
        "x": 330,
        "y": 160,
                "3c839915820df949",
                "f62c08cb2bed5705"
        "id": "3c839915820df949",
        "type": "csv",
        "sep": ",",
        "hdrin": true,
        "hdrout": "",
        "multi": "mult",
        "ret": "\\n",
        "temp": "",
        "skip": "0",
        "strings": true,
        "include_empty_strings": false,
        "include_null_values": false,
        "x": 310,
        "y": 280,
                "88f2e89168793a99",
                "f62c08cb2bed5705"
        "id": "88f2e89168793a99",
        "type": "function",
        "name": "graph generate",
        "func": "var payload=msg.payload;\n\nvar a1=[];\nvar a2=[];\nvar a3=[];\nvar a4=[];\nvar a5=[];\nvar a6=[];\n\nfor(let i=0;i<payload.length;i++)\n{\nvar timep=(payload[i][\"TIME\"]);\nvar temp1={\"x\": time, \"y\": parseInt(payload[i][\"A\"])};\nvar temp2={\"x\": time, \"y\": parseInt(payload[i][\"B\"])};\nvar temp3={\"x\": time, \"y\": parseInt(payload[i][\"C\"])};\nvar temp4={\"x\": time, \"y\": parseInt(payload[i][\"D\"])};\nvar temp5={\"x\": time, \"y\": parseInt(payload[i][\"E\"])};\nvar temp6={\"x\": time, \"y\": parseInt(payload[i][\"F\"])};\n\na1.push(temp1);\na2.push(temp2);\na3.push(temp3);\na4.push(temp4);\na5.push(temp5);\na6.push(temp6);\n \n \n //\n \n \n}\n\ndata_out=[a1,a2,a3,a4,a5,a6];\nmsg.payload=[{\n\"series\": [\"A\",\"B\",\"C\",\"D\",\"E\",\"F\"],\n\"DATA\":data_out,\n\"labels\": [\"A\",\"B\",\"C\",\"D\",\"E\",\"F\"]\n}];\n\nreturn msg;",
        "outputs": 1,
        "noerr": 0,
        "initialize": "",
        "finalize": "",
        "libs": [],
        "x": 340,
        "y": 480,
                "f62c08cb2bed5705",
                "aec05244f53c2688"
        "id": "aec05244f53c2688",
        "type": "ui_chart",
        "group": "2ac8e3fa.8b8584",
        "order": 5,
        "width": 0,
        "height": 0,
        "label": "Time Graph Test",
        "chartType": "line",
        "legend": "true",
        "xformat": "HH:mm:ss",
        "interpolate": "linear",
        "nodata": "",
        "dot": false,
        "ymin": "",
        "ymax": "",
        "removeOlder": 1,
        "removeOlderPoints": "",
        "removeOlderUnit": "3600",
        "cutout": 0,
        "useOneColor": false,
        "useUTC": false,
        "colors": [
            "#400000",
            "#ff8000",
            "#ff7f0e",
            "#2ca02c",
            "#98df8a",
            "#d62728",
            "#ff9896",
            "#9467bd",
            "#c5b0d5"
        "outputs": 1,
        "useDifferentColor": false,
        "className": "",
        "x": 720,
        "y": 380,
                "f62c08cb2bed5705"
        "id": "2ac8e3fa.8b8584",
        "type": "ui_group",
        "name": "Default",
        "tab": "ebb1ed1c.5ebe2",
        "order": 1,
        "disp": true,
        "width": "12",
        "collapse": false,
        "className": ""
        "id": "ebb1ed1c.5ebe2",
        "type": "ui_tab",
        "name": "Home",
        "icon": "dashboard",
        "disabled": false,
        "hidden": false
May I suggest you start with first establishing the chart plotting the data.
Get the chart node and connect two inject nodes into it.
In the first inject node copy/paste the first line (from what you posted) 09:21.3,-3.984,2.188,1.563,-0.165,0.105,0.057
and in the second node put the second line.
DEPLOY it then press the buttons to inject the two lines of data and see what you see.
Report back when done and we can move from there.
But also - in passing - I see you are using windows.
It has been a LONG TIME since I used it but this is ringing alarm bells for not looking right:
I may be wrong - and usually am - but I thought I would mention it.
Your function has some typo's and the TIME data needs to be a timestamp, so needs converting
here is an example
[{"id":"645ff7dc.625cc8","type":"template","z":"bf9e1e33.030598","name":"","field":"payload","fieldType":"msg","format":"handlebars","syntax":"mustache","template":"TIME,IA,IB,IC,VA,VB,VC\n09:21.3,-3.984,2.188,1.563,-0.165,0.105,0.057\n09:22.3,-3.984,1.406,2.266,-0.169,0.077,0.089\n09:23.3,-3.75,0.703,2.734,-0.161,0.045,0.111\n","output":"str","x":350,"y":2920,"wires":[["3fc27f3d.c0102"]]},{"id":"3fc27f3d.c0102","type":"csv","z":"bf9e1e33.030598","name":"","sep":",","hdrin":true,"hdrout":"","multi":"mult","ret":"\\n","temp":"","skip":"0","strings":true,"include_empty_strings":false,"include_null_values":false,"x":500,"y":2920,"wires":[["cad4c1f8.ea263"]]},{"id":"756d43fa.c8ddfc","type":"inject","z":"bf9e1e33.030598","name":"","props":[{"p":"payload"},{"p":"topic","vt":"str"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"start","payload":"1","payloadType":"num","x":200,"y":2920,"wires":[["645ff7dc.625cc8"]]},{"id":"cad4c1f8.ea263","type":"function","z":"bf9e1e33.030598","name":"graph generate","func":"let payload=msg.payload;\n\nlet data = [[],[],[],[],[],[]];\nfor(let i=0;i<payload.length;i++){\n    let time = payload[i].TIME.split(\".\");\n    time[1] = time[1].padStart(2,\"0\");\n    time = time.join(\":\");\n    time = new Date(\"1970-01-01T\"+time);\n    data[0].push({\"x\": time, \"y\": payload[i].IA});\n    data[1].push({\"x\": time, \"y\": payload[i].IB});\n    data[2].push({\"x\": time, \"y\": payload[i].IC});\n    data[3].push({\"x\": time, \"y\": payload[i].VA});\n    data[4].push({\"x\": time, \"y\": payload[i].VB});\n    data[5].push({\"x\": time, \"y\": payload[i].VC});\n}\nlet labels = msg.columns.split(\",\").slice(1);\n\nmsg.payload=[{\n\"series\": labels,\n\"data\":data,\n\"labels\": labels\n}];\n\nreturn msg;","outputs":1,"noerr":0,"initialize":"","finalize":"","x":690,"y":2920,"wires":[["6b7aa11a.55a6f","9ad4c905.297688"]]},{"id":"6b7aa11a.55a6f","type":"ui_chart","z":"bf9e1e33.030598","name":"","group":"c74b14d2.15e9f8","order":5,"width":0,"height":0,"label":"Time Graph Test","chartType":"line","legend":"true","xformat":"HH:mm:ss","interpolate":"linear","nodata":"","dot":false,"ymin":"","ymax":"","removeOlder":1,"removeOlderPoints":"","removeOlderUnit":"3600","cutout":0,"useOneColor":false,"useUTC":false,"colors":["#400000","#ff8000","#ff7f0e","#2ca02c","#98df8a","#d62728","#ff9896","#9467bd","#c5b0d5"],"outputs":1,"useDifferentColor":false,"className":"","x":940,"y":2920,"wires":[[]]},{"id":"9ad4c905.297688","type":"debug","z":"bf9e1e33.030598","name":"","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"true","targetType":"full","statusVal":"","statusType":"auto","x":960,"y":2800,"wires":[]},{"id":"c74b14d2.15e9f8","type":"ui_group","name":"Default","tab":"ebb1ed1c.5ebe2","order":1,"disp":true,"width":"12","collapse":false,"className":""},{"id":"ebb1ed1c.5ebe2","type":"ui_tab","name":"Home","icon":"dashboard","disabled":false,"hidden":false}]
I have simulated your file read node with a template, so just replace the template node.
[edit] fixed padding in time string
I got it! Thank you so much E1cid
Please help, the csv file is read and transferred to the dashboard
AGVName,Date,Time,B1C1,B1C2,B1Temp,Current,SOC
107102,2022/2/8,00:04.8,3.427,3.477,33,192.7,61
107102,2022/2/8,00:11.7,3.449,3.503,33,193.2,61
107102,2022/2/8,00:18.5,3.466,3.524,33,192.9,62
107102,2022/2/8,00:25.3,3.474,3.536,33,192.7,62
107102,2022/2/8,00:32.2,3.481,3.545,33,193,62
107102,2022/2/8,00:39.0,3.361,3.384,33,-20.9,63
107102,2022/2/8,00:45.9,3.341,3.365,33,-13.8,63
107102,2022/2/8,00:52.7,3.326,3.343,33,-14.2,63
107102,2022/2/8,00:59.6,3.312,3.326,33,-14.7,63
107102,2022/2/8,01:06.5,3.306,3.313,33,-13.8,63
107102,2022/2/8,01:13.3,3.299,3.305,33,-15.9,63
107102,2022/2/8,01:20.2,3.291,3.291,33,-18.9,63
107102,2022/2/8,01:27.0,3.286,3.283,33,-15.7,63
107102,2022/2/8,01:33.9,3.288,3.284,33,-13.4,63
107102,2022/2/8,01:40.7,3.288,3.283,33,-12.4,63
107102,2022/2/8,01:47.6,3.281,3.27,33,-19.9,63
107102,2022/2/8,01:54.5,3.279,3.267,33,-17.1,63
107102,2022/2/8,02:01.3,3.278,3.265,33,-17.7,63
107102,2022/2/8,02:08.1,3.276,3.262,33,-19.1,63
107102,2022/2/8,02:15.0,3.276,3.262,33,-16.3,63
107102,2022/2/8,02:22.6,3.279,3.267,33,-13.2,63
107102,2022/2/8,02:29.4,3.278,3.265,33,-13.8,63
107102,2022/2/8,02:36.3,3.278,3.267,33,-12.8,63
107102,2022/2/8,02:43.1,3.277,3.264,33,-14,63
107102,2022/2/8,02:50.0,3.277,3.264,33,-14,63
107102,2022/2/8,02:56.8,3.276,3.263,33,-12.2,63
107102,2022/2/8,03:03.7,3.279,3.267,33,-11.4,63
107102,2022/2/8,03:10.5,3.267,3.248,33,-10.2,63
107102,2022/2/8,03:17.3,3.277,3.265,33,-10.4,63
107102,2022/2/8,03:24.2,3.277,3.265,33,-10,63
107102,2022/2/8,03:31.0,3.269,3.254,33,-20.9,63
107102,2022/2/8,03:37.8,3.272,3.257,33,-16.9,63
107102,2022/2/8,03:44.6,3.273,3.259,33,-14.2,63
107102,2022/2/8,03:51.5,3.268,3.252,33,-22.4,63
