Problem visualizing CSV data in a Line chart. I can read the timestamp and temperature data but i don't see the graph
        "id": "e4e30c42d69f0e9c",
        "type": "tab",
        "label": "File Browser",
        "disabled": false,
        "info": "",
        "env": []
        "id": "4fa73dd9.83cca4",
        "type": "comment",
        "z": "e4e30c42d69f0e9c",
        "name": "File Browser",
        "info": "1) Update the default folder in the Init node\n2) Update the default folder in the Reset node as well\n3) You can duplicate the Reset nodes and use them as saved shortcuts\n4) Check the Convert Timestamps function node if you want to see your dates in a different format. I just used the Javascript toISOString format.\n5) The Graph button can read any CSV file which have any number of values, but the first column always contains a timestamp column with javascript timestamp of the data point.",
        "x": 90,
        "y": 40,
        "id": "993d7272.843ae",
        "type": "fs-file-lister",
        "name": "Files",
        "start": "C:\\Users\\177008EIE\\Desktop",
        "pattern": "*.*",
        "folders": "*",
        "hidden": false,
        "lstype": "files",
        "path": true,
        "single": true,
        "depth": 0,
        "stat": true,
        "showWarnings": false,
        "x": 490,
        "y": 140,
                "dd88bd23.37cde"
        "id": "d185a45.2327a58",
        "type": "inject",
        "name": "Init",
        "props": [
                "p": "payload"
                "p": "topic",
                "vt": "str"
        "repeat": "",
        "crontab": "",
        "once": true,
        "onceDelay": 0.1,
        "topic": "change",
        "payload": "D:\\Node_red\\",
        "payloadType": "str",
        "x": 90,
        "y": 100,
                "3d4e5e51.bdf952"
        "id": "a715f7a4.a398a8",
        "type": "ui_button",
        "group": "160e81fb.f1c86e",
        "order": 1,
        "width": "2",
        "height": "1",
        "passthru": false,
        "label": "Refresh",
        "tooltip": "",
        "color": "",
        "bgcolor": "",
        "className": "",
        "icon": "refresh",
        "payload": "",
        "topic": "refresh",
        "topicType": "str",
        "x": 80,
        "y": 140,
                "3d4e5e51.bdf952"
        "id": "eb17c7ee.e61988",
        "type": "ui_dropdown",
        "name": "File Selector",
        "label": "",
        "tooltip": "",
        "place": "Select a file",
        "order": 9,
        "width": "5",
        "height": "1",
        "passthru": false,
        "multiple": false,
        "options": [
                "label": "",
                "value": "",
                "type": "str"
        "payload": "",
        "topic": "",
        "topicType": "str",
        "className": "",
        "x": 890,
        "y": 140,
                "be4830df.5775d"
        "id": "dd88bd23.37cde",
        "type": "function",
        "name": "Format data",
        "func": "// format the data for the dropdown\nmsg.options = [];\nfor (var i=0; i<msg.payload.length; i++) {\n    // This is a file\n    obj = {};\n    obj [msg.payload[i].name.replace(/^.*(\\\\|\\/|\\:)/, '')]=msg.payload[i].name;\n    msg.options.push(obj);\n}\nmsg.payload={};\nreturn msg;",
        "outputs": 1,
        "noerr": 0,
        "initialize": "",
        "finalize": "",
        "libs": [],
        "x": 690,
        "y": 140,
                "eb17c7ee.e61988"
        "id": "7b7e0d58.05e244",
        "order": 10,
        "width": "2",
        "height": "1",
        "passthru": false,
        "label": "Delete",
        "tooltip": "",
        "color": "",
        "bgcolor": "",
        "icon": "delete",
        "payload": "",
        "topic": "",
        "x": 110,
        "y": 300,
                "8da8147a.999af8"
        "id": "7d490dd1.8458b4",
        "type": "function",
        "name": "Get filename",
        "func": "// Get the filename from the flow context\nlet filename = flow.get(\"fileselected\");\n\n// check, if the filename is undefined that means it does not exist yet, nothing is selected yet\n// return: do not output anything\nif (filename===undefined) {\n    return;\n}\n\n// return the filename to the file-in node to delete\nmsg.filename = filename;\n\nif (msg.filename.replace(/^.*(\\\\|\\/|\\:)/, '')[0]!==\".\") {\n    // Only do this if this is a file, we don't delete folders\n    // and delete the context/selection as we are deleting the file as well\n    flow.set(\"fileselected\");\n    return msg;\n}",
        "outputs": 1,
        "noerr": 0,
        "x": 310,
        "y": 360,
                "372ee262.fc94de"
        "id": "372ee262.fc94de",
        "type": "file",
        "name": "Delete file",
        "filename": "",
        "appendNewline": true,
        "createDir": false,
        "overwriteFile": "delete",
        "encoding": "none",
        "x": 520,
        "y": 360,
                "993d7272.843ae",
                "5219875b.c070d8"
        "id": "554f0095.ac1b2",
        "type": "ui_toast",
        "position": "dialog",
        "displayTime": "3",
        "highlight": "",
        "sendall": false,
        "outputs": 1,
        "ok": "Yes",
        "cancel": "No",
        "raw": false,
        "className": "",
        "topic": "",
        "name": "Confirmation",
        "x": 490,
        "y": 300,
                "24df84fe.ebf45c"
        "id": "8da8147a.999af8",
        "type": "change",
        "name": "Set message",
        "rules": [
                "t": "set",
                "p": "topic",
                "pt": "msg",
                "to": "Delete confirmation",
                "tot": "str"
                "t": "set",
                "p": "payload",
                "pt": "msg",
                "to": "Are you sure you want to delete this file?",
                "tot": "str"
        "action": "",
        "property": "",
        "from": "",
        "to": "",
        "reg": false,
        "x": 290,
        "y": 300,
                "554f0095.ac1b2"
        "id": "24df84fe.ebf45c",
        "type": "switch",
        "property": "payload",
        "propertyType": "msg",
        "rules": [
                "t": "eq",
                "v": "Yes",
                "vt": "str"
        "checkall": "true",
        "repair": false,
        "outputs": 1,
        "x": 690,
        "y": 300,
                "7d490dd1.8458b4"
        "id": "3d4e5e51.bdf952",
        "type": "function",
        "name": "Folder handling",
        "func": "let folder = context.get(\"folder\");\nif (folder===undefined) {\n    folder=\"/\";\n    context.set(\"folder\", folder);\n}\n\nlet hidden = context.get(\"hidden\");\nif (hidden===undefined) {\n    hidden=false;\n    context.set(\"hidden\", hidden);\n}\n\nif (msg.topic===\"up\") {\n    var the_arr = folder.split('/');\n    the_arr.pop();\n    folder=the_arr.join('/'); \n    context.set(\"folder\", folder);\n}\nif (msg.topic===\"change\") {\n    folder=msg.payload;    \n    context.set(\"folder\", folder);\n}\nif (msg.topic===\"hidden\") {\n    hidden=msg.payload;    \n    context.set(\"hidden\", hidden);\n}\n\nmsg.payload = {\"start\":folder, \"hidden\": hidden};\nreturn msg;",
        "outputs": 1,
        "noerr": 0,
        "initialize": "",
        "finalize": "",
        "libs": [],
        "x": 280,
        "y": 200,
                "993d7272.843ae",
                "399ac341.7d43bc",
                "5219875b.c070d8"
        "id": "399ac341.7d43bc",
        "type": "ui_text",
        "order": 4,
        "width": "9",
        "height": "1",
        "label": "Folder:",
        "format": "{{msg.payload.start}}",
        "layout": "row-left",
        "className": "",
        "x": 480,
        "y": 80,
        "id": "b40ea1d8.c700a",
        "order": 3,
        "width": "2",
        "height": "1",
        "passthru": false,
        "label": "Up",
        "tooltip": "",
        "color": "",
        "bgcolor": "",
        "className": "",
        "icon": "arrow_upwards",
        "payload": "",
        "topic": "up",
        "topicType": "str",
        "x": 90,
        "y": 220,
                "3d4e5e51.bdf952"
        "id": "80940e39.5035b",
        "order": 8,
        "width": "2",
        "height": "1",
        "passthru": false,
        "label": "Open",
        "tooltip": "",
        "color": "",
        "bgcolor": "",
        "className": "",
        "icon": "folder_open",
        "payload": "",
        "topic": "",
        "topicType": "str",
        "x": 110,
        "y": 420,
                "8c1dfaac.979588"
        "id": "8c1dfaac.979588",
        "type": "function",
        "name": "Change folder",
        "func": "// Get the filename from the flow context\nlet folderselected = flow.get(\"folderselected\");\n\n// check, if the filename is undefined that means it does not exist yet, nothing is selected yet\n// return: do not output anything\nif (folderselected===undefined) {\n    return;\n}\n\nmsg.topic = \"change\";\nmsg.payload = folderselected;\n\nreturn msg;",
        "outputs": 1,
        "noerr": 0,
        "initialize": "",
        "finalize": "",
        "libs": [],
        "x": 320,
        "y": 420,
                "3d4e5e51.bdf952"
        "id": "58414ec4.c716e",
        "order": 2,
        "width": "2",
        "height": "1",
        "passthru": false,
        "label": "Reset",
        "tooltip": "",
        "color": "",
        "bgcolor": "",
        "className": "",
        "icon": "autorenew",
        "topic": "change",
        "topicType": "str",
        "x": 90,
        "y": 180,
                "3d4e5e51.bdf952"
        "id": "5219875b.c070d8",
        "name": "Folders",
        "pattern": "*.*",
        "folders": "*",
        "hidden": false,
        "lstype": "directories",
        "path": true,
        "single": true,
        "depth": 0,
        "stat": true,
        "x": 500,
        "y": 240,
                "ebc234be.d53fe8"
        "id": "37485c24.212054",
        "name": "Folder Selector",
        "label": "",
        "tooltip": "",
        "place": "Select a folder",
        "order": 7,
        "width": "5",
        "height": "1",
        "passthru": false,
        "options": [
                "label": "",
                "value": "",
                "type": "str"
        "payload": "",
        "topic": "",
        "x": 900,
        "y": 240,
                "2875c79f.531558"
        "id": "ebc234be.d53fe8",
        "type": "function",
        "func": "// format the data for the dropdown\nmsg.options = [];\nfor (var i=0; i<msg.payload.length; i++) {\n    // This is a foler\n    obj = {};\n    obj [\"[\"+msg.payload[i].name.replace(/^.*(\\\\|\\/|\\:)/, '')+\"]\"]=msg.payload[i].name;\n    msg.options.push(obj);\n}\nmsg.payload={};\nreturn msg;",
        "outputs": 1,
        "noerr": 0,
        "x": 690,
        "y": 240,
                "37485c24.212054"
        "id": "be4830df.5775d",
        "type": "change",
        "name": "Save selection",
        "rules": [
                "t": "set",
                "p": "fileselected",
                "pt": "flow",
                "to": "payload",
                "tot": "msg"
        "action": "",
        "property": "",
        "from": "",
        "to": "",
        "reg": false,
        "x": 1100,
        "y": 140,
        "id": "2875c79f.531558",
        "type": "change",
        "rules": [
                "t": "set",
                "p": "folderselected",
                "pt": "flow",
                "to": "payload",
                "tot": "msg"
        "action": "",
        "property": "",
        "from": "",
        "to": "",
        "reg": false,
        "x": 1100,
        "y": 240,
        "id": "928e60a7.994be",
        "type": "ui_switch",
        "label": "Hidden",
        "tooltip": "Show hidden files or not",
        "order": 5,
        "width": "2",
        "height": "1",
        "passthru": false,
        "decouple": "false",
        "topic": "hidden",
        "style": "",
        "onvalue": "true",
        "onvalueType": "bool",
        "onicon": "check_box",
        "oncolor": "#000000",
        "offvalue": "false",
        "offvalueType": "bool",
        "officon": "check_box_outline_blank",
        "offcolor": "#000000",
        "x": 80,
        "y": 260,
                "3d4e5e51.bdf952"
        "id": "bdb8660cab2fb6ee",
        "order": 11,
        "width": "2",
        "height": "1",
        "passthru": false,
        "label": "Graph",
        "tooltip": "",
        "color": "",
        "bgcolor": "",
        "className": "",
        "icon": "show_chart",
        "payload": "",
        "topic": "",
        "topicType": "str",
        "x": 90,
        "y": 540,
                "4af56c96d2c84bd8"
        "id": "4af56c96d2c84bd8",
        "type": "function",
        "func": "// Get the filename from the flow context\nlet filename = flow.get(\"fileselected\");\n\n// check, if the filename is undefined that means it does not exist yet, nothing is selected yet\n// return: do not output anything\nif (filename===undefined) {\n    return;\n}\n\n// return the filename to the file-in node to delete\nmsg.filename = filename;\n\nif (msg.filename.replace(/^.*(\\\\|\\/|\\:)/, '')[0]!==\".\") {\n    // Only do this if this is a file, we don't delete folders\n    return msg;\n}",
        "outputs": 1,
        "noerr": 0,
        "initialize": "",
        "finalize": "",
        "libs": [],
        "x": 258,
        "y": 540,
                "24eacfda49cb6762"
        "id": "24eacfda49cb6762",
        "type": "file in",
        "filename": "",
        "format": "utf8",
        "chunk": false,
        "sendError": false,
        "encoding": "none",
        "allProps": false,
        "x": 438,
        "y": 540,
                "8726e1bb706a2891"
        "id": "8726e1bb706a2891",
        "type": "csv",
        "sep": ",",
        "hdrin": false,
        "hdrout": "none",
        "multi": "mult",
        "ret": "\\n",
        "temp": "",
        "skip": "0",
        "strings": true,
        "include_empty_strings": false,
        "include_null_values": false,
        "x": 588,
        "y": 540,
                "3293d2ddeabf37ba"
        "id": "135d930d7215ffff",
        "type": "debug",
        "active": true,
        "tosidebar": true,
        "console": false,
        "tostatus": false,
        "complete": "false",
        "x": 1170,
        "y": 340,
        "id": "fc1bde06c37f5f44",
        "type": "debug",
        "active": false,
        "tosidebar": true,
        "console": false,
        "tostatus": false,
        "x": 670,
        "y": 400,
        "id": "3293d2ddeabf37ba",
        "type": "function",
        "name": "Format data for chart",
        "func": "var chart = [{\n    \"series\":[],\n    \"data\":[msg.payload],\n    \"labels\":[\"\"]\n}];\n\n\n/*\nvar pressure = [];\nvar out2 = [];\n\nfor (var i=0; i<msg.payload.length; i++) {\n    pressure.push({\"x\":msg.payload[i].timestamp, \"y\":msg.payload[i].pressure});\n    out2.push({\"x\":msg.payload[i].timestamp, \"y\":msg.payload[i].out2*200});\n\n}\nchart[0].data.push(pressure);\nchart[0].data.push(out2);\n*/\n\nlet columns = 0;\n\nfor(var series in msg.payload[0]) {\n    if(series!==\"timestamp\") {\n        chart[0].series.push(series);\n        chart[0].data.push([]);\n        columns++;\n    }\n}\n\n\nfor (var j=0; j<msg.payload.length; j++) {\n   for(var i=0;i<columns;i++) {\n       chart[0].data[i].push({\"x\":msg.payload[j].timestamp, \"y\":msg.payload[j][chart[0].series[i]]});\n   } \n}\n\n\n\n\nmsg.payload = chart;\n\nreturn msg;",
        "outputs": 1,
        "noerr": 0,
        "initialize": "",
        "finalize": "",
        "libs": [],
        "x": 800,
        "y": 540,
                "7312f2a78a4eef04"
        "id": "7312f2a78a4eef04",
        "type": "ui_chart",
        "order": 12,
        "width": "18",
        "height": "6",
        "label": "",
        "chartType": "line",
        "legend": "false",
        "xformat": "HH:mm:ss",
        "interpolate": "linear",
        "nodata": "",
        "dot": false,
        "ymin": "",
        "ymax": "",
        "removeOlder": 1,
        "removeOlderPoints": "",
        "removeOlderUnit": "3600",
        "cutout": 0,
        "useOneColor": false,
        "useUTC": false,
        "colors": [
            "#1f77b4",
            "#aec7e8",
            "#ff7f0e",
            "#2ca02c",
            "#98df8a",
            "#d62728",
            "#ff9896",
            "#9467bd",
            "#c5b0d5"
        "outputs": 1,
        "useDifferentColor": false,
        "className": "",
        "x": 1090,
        "y": 580,
        "id": "160e81fb.f1c86e",
        "type": "ui_group",
        "tab": "c2e47548e62261b9",
        "order": 3,
        "disp": true,
        "width": "18",
        "collapse": false
        "id": "c2e47548e62261b9",
        "type": "ui_tab",
        "name": "Home",
        "icon": "dashboard",
        "order": 1,
        "disabled": false,
        "hidden": false
* List item
The Csv file has two column one is timestamp and temperature data .I have put the debug node at the end of chart but not sure what message I am recieving
Thankyou in Advance ,.
debug node
Do you mean that is the data going into the chart? That is what is important. The data going in should follow the format described in the Line Charts section of node-red-dashboard/Charts.md at master · node-red/node-red-dashboard · GitHub
Your chart function is an endless loop and will eventually crash node-red.
Here is an example of fitting your csv data to chart. If you look in the csv node you will see i named the columns, this creates the correct format and the payload just needs to be added to the chart array in the function
e.g.
[{"id":"9ac95c1a.1bfef8","type":"inject","z":"e4e30c42d69f0e9c","name":"","props":[{"p":"payload"},{"p":"topic","vt":"str"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","payload":"","payloadType":"date","x":200,"y":520,"wires":[["db6f904f.346b"]]},{"id":"db6f904f.346b","type":"template","z":"e4e30c42d69f0e9c","name":"","field":"payload","fieldType":"msg","format":"handlebars","syntax":"mustache","template":"12.34,20\n12.46,21\n12.51,22\n","output":"str","x":380,"y":520,"wires":[["8726e1bb706a2891"]]},{"id":"8726e1bb706a2891","type":"csv","z":"e4e30c42d69f0e9c","name":"","sep":",","hdrin":false,"hdrout":"none","multi":"mult","ret":"\\n","temp":"x,y","skip":"0","strings":true,"include_empty_strings":false,"include_null_values":false,"x":588,"y":540,"wires":[["3293d2ddeabf37ba"]]},{"id":"3293d2ddeabf37ba","type":"function","z":"e4e30c42d69f0e9c","name":"Format data for chart","func":"msg.payload = [{\n    \"series\":[],\n    \"data\":[msg.payload],\n    \"labels\":[\"\"]\n}];\n\n\nreturn msg;","outputs":1,"noerr":0,"initialize":"","finalize":"","x":800,"y":540,"wires":[["30af4990.19ab5e"]]},{"id":"30af4990.19ab5e","type":"debug","z":"e4e30c42d69f0e9c","name":"","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"false","statusVal":"","statusType":"auto","x":860,"y":640,"wires":[]}]
        "id": "2519dd0d.54d6b2",
        "z": "c928a68ae04c5a4e",
        "order": 11,
        "width": "2",
        "height": "1",
        "passthru": false,
        "label": "Graph",
        "tooltip": "",
        "color": "",
        "bgcolor": "",
        "className": "",
        "payload": "",
        "topic": "",
        "topicType": "str",
        "x": 150,
        "y": 120,
                "30f41c01.358a54"
        "id": "30f41c01.358a54",
        "type": "function",
        "outputs": 1,
        "noerr": 0,
        "initialize": "",
        "finalize": "",
        "libs": [],
        "x": 290,
        "y": 140,
                "4f4072b6.0c320c"
        "id": "4f4072b6.0c320c",
        "type": "file in",
        "filename": "",
        "format": "utf8",
        "chunk": false,
        "sendError": false,
        "encoding": "none",
        "allProps": false,
        "x": 500,
        "y": 120,
                "8b41634cc90d6045"
        "id": "8b41634cc90d6045",
        "type": "csv",
        "sep": ",",
        "hdrin": false,
        "hdrout": "none",
        "multi": "mult",
        "ret": "\\n",
        "temp": "x,y",
        "skip": "0",
        "strings": true,
        "x": 528,
        "y": 60,
                "45faee8591fa2d28"
        "id": "45faee8591fa2d28",
        "type": "function",
        "func": "msg.payload = [{\n    \"series\":[],\n    \"data\":[msg.payload],\n    \"labels\":[\"\"]\n}];\n\n\nreturn msg;",
        "outputs": 1,
        "noerr": 0,
        "initialize": "",
        "finalize": "",
        "libs": [],
        "x": 740,
        "y": 60,
                "8d9b4a9ae617b6c1",
                "5022cb53.8adc44"
        "id": "5022cb53.8adc44",
        "type": "ui_chart",
        "order": 12,
        "width": "18",
        "height": "6",
        "label": "",
        "legend": "false",
        "nodata": "",
        "dot": false,
        "ymin": "",
        "ymax": "",
        "removeOlder": 1,
        "cutout": 0,
        "useUTC": false,
        "colors": [
            "#1f77b4",
            "#aec7e8",
            "#ff7f0e",
            "#2ca02c",
            "#98df8a",
            "#d62728",
            "#ff9896",
            "#9467bd",
            "#c5b0d5"
        "outputs": 1,
        "className": "",
        "x": 1060,
        "y": 120,
        "id": "8d9b4a9ae617b6c1",
        "type": "debug",
        "active": true,
        "tosidebar": true,
        "console": false,
        "tostatus": false,
        "statusVal": "",
        "statusType": "auto",
        "x": 1050,
        "y": 20,
        "type": "ui_group",
        "tab": "5b94a1d5e0dbd838",
        "order": 3,
        "disp": true,
        "width": "18",
        "collapse": false,
        "className": ""
        "id": "5b94a1d5e0dbd838",
        "type": "ui_tab",
        "name": "Home",
        "order": 1,
        "disabled": false,
        "hidden": false
Thankyou for response . I have replaced the logic with the changes but i Could not see the graph. Is their any limit to data which the csv file holding . I have attached the sample csv file which I am Reading for your reference.
Time | Temperature
13:53 27.96
13:53 24.65
13:53 24.49
13:53 24.9
13:53 27.8
13:53 23.36
13:53 25.7
13:53 24.98
13:53 24.73
13:53 24.41
13:53 25.06
13:53 25.22
13:53 26.26
13:53 27.15
13:53 25.3
13:53 24.49
13:53 24.9
13:53 25.78
13:53 24.9
13:53 23.2
13:53 27.71
13:53 26.18
13:53 27.88
13:53 25.78
13:53 26.83
13:53 23.44
13:53 25.46
13:53 25.3
13:53 25.06
13:53 25.94
13:53 24.25
13:53 25.22
13:53 24.41
13:53 25.62
13:53 26.02
13:53 26.26
13:53 25.86
13:53 25.7
13:53 24.65
13:53 28.84
13:53 26.83
13:53 24.73
13:53 24.49
13:53 24.57
13:53 27.39
13:53 27.71
13:53 23.93
13:54 26.02
13:54 25.06
13:54 25.78
13:54 25.46
13:54 25.3
13:54 25.54
13:54 25.78
13:54 25.94
13:54 24.01
13:54 25.06
13:54 25.78
13:54 25.7
13:54 25.7
13:54 24.01
13:54 26.1
13:54 24.81
13:54 26.67
13:54 25.78
13:54 25.78
13:54 25.94
13:54 25.78
13:54 26.67
13:54 25.78
OK now we see your data the time format of the x (time) is not acceptable for the chart.
I have added a loop in function to fix the time and added time to each to separate them.
It would be better to store your time in a timestamp or ISO format, then you would not need to fiddle with the data
e.g.
timestamp | temp | readable time format
49980000  27.96  13:53
[{"id":"a35b843e.16c08","type":"inject","z":"bf9e1e33.030598","name":"","props":[{"p":"payload"},{"p":"topic","vt":"str"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","payload":"","payloadType":"date","x":470,"y":1240,"wires":[["78f4c462.2d2c54"]]},{"id":"78f4c462.2d2c54","type":"template","z":"bf9e1e33.030598","name":"","field":"payload","fieldType":"msg","format":"handlebars","syntax":"mustache","template":"13:53\t27.96\n13:53\t24.65\n13:53\t24.49\n13:53\t24.9\n13:53\t27.8\n13:53\t23.36\n13:53\t25.7\n13:53\t24.98\n13:53\t24.73\n13:53\t24.41\n13:53\t25.06\n13:53\t25.22\n13:53\t26.26\n13:53\t27.15\n13:53\t25.3\n13:53\t24.49\n13:53\t24.9\n13:53\t25.78\n13:53\t24.9\n13:53\t23.2\n13:53\t27.71\n13:53\t26.18\n13:53\t27.88\n13:53\t25.78\n13:53\t26.83\n13:53\t23.44\n13:53\t25.46\n13:53\t25.3\n13:53\t25.06\n13:53\t25.94\n13:53\t24.25\n13:53\t25.22\n13:53\t24.41\n13:53\t25.62\n13:53\t26.02\n13:53\t26.26\n13:53\t25.86\n13:53\t25.7\n13:53\t24.65\n13:53\t28.84\n13:53\t26.83\n13:53\t24.73\n13:53\t24.49\n13:53\t24.57\n13:53\t27.39\n13:53\t27.71\n13:53\t23.93\n13:54\t26.02\n13:54\t25.06\n13:54\t25.78\n13:54\t25.46\n13:54\t25.3\n13:54\t25.54\n13:54\t25.78\n13:54\t25.94\n13:54\t24.01\n13:54\t25.06\n13:54\t25.78\n13:54\t25.7\n13:54\t25.7\n13:54\t24.01\n13:54\t26.1\n13:54\t24.81\n13:54\t26.67\n13:54\t25.78\n13:54\t25.78\n13:54\t25.94\n13:54\t25.78\n13:54\t26.67\n13:54\t25.78","output":"str","x":170,"y":1160,"wires":[["8b41634cc90d6045"]]},{"id":"8b41634cc90d6045","type":"csv","z":"bf9e1e33.030598","name":"","sep":"\\t","hdrin":false,"hdrout":"none","multi":"mult","ret":"\\n","temp":"x,y","skip":"0","strings":true,"include_empty_strings":false,"include_null_values":false,"x":478,"y":1160,"wires":[["45faee8591fa2d28"]]},{"id":"45faee8591fa2d28","type":"function","z":"bf9e1e33.030598","name":"Format data for chart","func":"for(let i = 0; i< msg.payload.length; i++){\n    let time_parts = msg.payload[i].x.split(\":\");\n    msg.payload[i].x = (Number(time_parts[0]) * 3600000) +(Number(time_parts[1]) * 60000) + (i *10000)\n}\n\n\nmsg.payload = [{\n    \"series\":[\"temp\"],\n    \"data\":[msg.payload],\n    \"labels\":[]\n}];\n\n\nreturn msg;","outputs":1,"noerr":0,"initialize":"","finalize":"","x":690,"y":1160,"wires":[["8d9b4a9ae617b6c1","5022cb53.8adc44"]]},{"id":"8d9b4a9ae617b6c1","type":"debug","z":"bf9e1e33.030598","name":"","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"false","statusVal":"","statusType":"auto","x":1000,"y":1120,"wires":[]},{"id":"5022cb53.8adc44","type":"ui_chart","z":"bf9e1e33.030598","name":"","group":"160e81fb.f1c86e","order":12,"width":"18","height":"6","label":"","chartType":"line","legend":"false","xformat":"HH:mm:ss","interpolate":"linear","nodata":"","dot":false,"ymin":"","ymax":"","removeOlder":1,"removeOlderPoints":"","removeOlderUnit":"3600","cutout":0,"useOneColor":false,"useUTC":false,"colors":["#1f77b4","#aec7e8","#ff7f0e","#2ca02c","#98df8a","#d62728","#ff9896","#9467bd","#c5b0d5"],"outputs":1,"useDifferentColor":false,"className":"","x":1010,"y":1220,"wires":[[]]},{"id":"160e81fb.f1c86e","type":"ui_group","name":"File Browser","tab":"5b94a1d5e0dbd838","order":3,"disp":true,"width":"18","collapse":false,"className":""},{"id":"5b94a1d5e0dbd838","type":"ui_tab","name":"Home","icon":"dashboard","order":1,"disabled":false,"hidden":false}]
The chart data should not over load the browser if you keep it below the pixel width, say 1000 item array.
Thankyou E1cid for the help . It works fine .I can able to visualize the data . But I am storing data continuously due to which the data showing on the graph little bit noise as the quantity is large . Is their way we can store data based on the date in a separate file . Like every day it should store data in a separate file with file name as date.
read this thread and the video link below. it may help.
https://discourse.nodered.org/t/re-generate-folder-every-30minute/57201/9?u=smanjunath211
Hello @E1cid I have one doubt on the timestamp. while visualizing the data in the graph in x axis it showing wrong timestamp . Instead Can we show the correct timestamp ?
Thankyou for the response @smanjunath211 . But it looks like it was removed from the site
It will be difficult as you store your time in HH:MM which is not very precise. As stated before you need to store in a timestamp or ISO format, This will give you precision, then no need to mess with the times. All the problems you are having would disappear and X axis labels would be correct. I suggest you fix the time you store in the csv file.
to limit the display of data to last 1000 add
msg.payload = msg.payload.splice(-1000);
to the start of your function
