Create the data points to send in Influxdb
Task: Points which, when drawn over time, form a sinus curve called X. All values of the
sinus curve should be above 0.
Here which node to be used to create this sinus curve point?
After creating the points, I need to send the data to my influxdb node.
Do you need to create a set of points all at once which will draw the graph or do you need to generate a sequence of points over time to build it up continuously?
Whichever is the answer the first thing to do is to decide on the mathematical formula that will determine the point values. That is obviously not a node-red question.
Is this a college task?
