I am looking for solution where I can create a line chart , audio waveforms on node-red defining x axis(voltage) and Y -axis(current).
Any ways that I can make use of dashboard board chart for this?
Couple of example's to explore
Yes you can use non time series format
e.g
"series": ["X" ],
"data": [ [5,6,9,10] ],
"labels": [ 24, 25, 23, 26 ]
where labels is the voltages and data the current
more info here about formats, also in the help text https://github.com/node-red/node-red-dashboard/blob/master/Charts.md
Just to check:
You are displaying an audio wave on a chart and want x to be the voltage?
So the wave is vertical on the screen?
Usually they are done horizontally.
Just checking.
It is charting current against voltage. The usual way of displaying that is to have volts on the x axis and current on the y, which is the stated requirement here.
I was just checking.
I am plotting voltage vs current waveform where I want to fetch real time data from serial input. plot the line chart. I am actually looking for a line where my real-time data is plotted on.
"id": "c6d1832664c2174f",
"type": "function",
"z": "b1d2a17489d1cb3e",
"func": "var m={};\nm.labels = [\"January\", \"February\", \"March\", \"April\", \"May\", \"June\", \"July\"];\nm.series = ['Series A', 'Series B', 'Series C'];\nreturn {payload:[m]};",
"outputs": 1,
"timeout": "",
"noerr": 0,
"initialize": "",
"finalize": "",
"libs": [],
"x": 300,
"y": 600,
"d7b0e6e47a33afbb"
"id": "d7b0e6e47a33afbb",
"type": "ui_chart",
"group": "89749fb7.87f01",
"order": 1,
"width": 0,
"height": 0,
"label": "line chart",
"chartType": "line",
"legend": "true",
"xformat": "auto",
"interpolate": "linear",
"nodata": "No Data",
"dot": false,
"ymin": "",
"ymax": "",
"removeOlder": 1,
"removeOlderPoints": "",
"removeOlderUnit": "3600",
"cutout": 0,
"useOneColor": false,
"useUTC": false,
"colors": [
"#1f77b4",
"#aec7e8",
"#ff7f0e",
"#2ca02c",
"#98df8a",
"#d62728",
"#ff9896",
"#9467bd",
"#c5b0d5"
"outputs": 1,
"useDifferentColor": false,
"className": "",
"x": 500,
"y": 600,
"id": "712902dc584e7d7e",
"type": "ui_button",
"group": "ab397e95.29ebe",
"order": 5,
"width": 0,
"height": 0,
"passthru": false,
"label": "array",
"tooltip": "",
"color": "",
"bgcolor": "",
"className": "",
"icon": "",
"payload": "",
"payloadType": "str",
"topic": "",
"topicType": "str",
"x": 110,
"y": 600,
"c6d1832664c2174f"
"id": "89749fb7.87f01",
"type": "ui_group",
"name": "Charts",
"tab": "d7901f40.2659d",
"order": 2,
"disp": false,
"width": "6"
"id": "ab397e95.29ebe",
"type": "ui_group",
"name": "Inputs",
"order": 1,
"disp": false,
"width": "6"
"id": "d7901f40.2659d",
"type": "ui_tab",
"name": "Charts",
"icon": "dashboard",
"order": 2
Slightly confused can you show an example of what the chart must look like, a sketch on a paper will do then post an image.
Also examples of incoming messages would help.
