Creating bar chart from a csv file shows nothing :(
Hello, I would like to display a value as a bar in a bar chart every 15 minutes. The period is 24 hours.
Like this:
Here is my flow and the debug output from "msg.generate"
The data looks okay to me. What is still missing so that it is displayed in the bar chart?
I get no scaling on the x axis can this be due to the time format?
Please post some actual data and your function and chart nodes as code rather than pictures.
The bar chart takes an array of values in the data array, and the times would be an array in the label property
Csv looks like:
Datum/Uhrzeit;Verbrauchswert;
00:00;0,000;
00:15;0,000;
12:15;46,000;
Here is my generate graph node:
function toTimestamp(strDate){
     var datum = Date.parse(strDate);
     return datum/1000;
var payload=msg.payload;
var data_out=[];
var a1=[];
var label_out=[];
var a2=[];
for(let i=0;i<payload.length;i++)
//var Data= "2022-03-9".split("-");
//var t=Data[2]+"/"+Data[1]+"/"+Data[0];
//var timestamp= toTimestamp(t+" "+payload[i]["Datum/Uhrzeit"]);
var timestamp= (payload[i]["Datum/Uhrzeit"])
var temp1={ "x": timestamp, "y":parseInt( payload[i]["Verbrauchswert"]) };
//var temp2={ "x": timestamp };
a1.push(temp1);
//a2.push(temp2);
//label_out=[a2];
data_out=[a1];
msg.payload=[{
"series": ["Test"],
"data":data_out,
"labels":["Test"]
@E1cid I loaded the timestamp(00:00, 00:15, 00:30 etc) into the label array but still nothing was displayed in the chart.
You are still creating an array of objects, not an array of values. There where examples of how a bar chart array should look in the link I provided.
[{"id":"eb353f29.727eb8","type":"inject","z":"bf9e1e33.030598","name":"","props":[{"p":"payload"},{"p":"topic","vt":"str"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","payload":"","payloadType":"date","x":160,"y":80,"wires":[["fb015cdd.41dc18"]]},{"id":"fb015cdd.41dc18","type":"template","z":"bf9e1e33.030598","name":"","field":"payload","fieldType":"msg","format":"handlebars","syntax":"mustache","template":"00:00;0,000;\n00:15;2,000;\n00:30;4,000;\n00:45;5,000;\n01:00;4,000;\n01:15;3,000;\n01:30;0,000;\n","output":"str","x":270,"y":100,"wires":[["80feb1c5.91d6f"]]},{"id":"80feb1c5.91d6f","type":"csv","z":"bf9e1e33.030598","name":"","sep":";","hdrin":"","hdrout":"none","multi":"mult","ret":"\\n","temp":"","skip":"0","strings":true,"include_empty_strings":"","include_null_values":"","x":410,"y":100,"wires":[["096d0b59bafc40bb"]]},{"id":"096d0b59bafc40bb","type":"function","z":"bf9e1e33.030598","name":"Werte","func":"let payload=msg.payload;\nlet labels= [];\nlet data = [];\nfor(let i=0;i<payload.length;i++){\n    data.push(parseInt( payload[i].col2));\n    labels.push(payload[i].col1);\n}\nmsg.payload=[{\n\"series\": [],\n\"data\":[data],\n\"labels\":labels\n}];\n\nreturn msg;","outputs":1,"noerr":0,"initialize":"","finalize":"","x":560,"y":100,"wires":[["cd26d599.ceb17","5604943f.63d1d4"]]},{"id":"cd26d599.ceb17","type":"debug","z":"bf9e1e33.030598","name":"","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"false","statusVal":"","statusType":"auto","x":690,"y":40,"wires":[]},{"id":"5604943f.63d1d4","type":"ui_chart","z":"bf9e1e33.030598","name":"","group":"2d4fe667.28f8ba","order":24,"width":0,"height":0,"label":"chart","chartType":"bar","legend":"false","xformat":"HH:mm:ss","interpolate":"linear","nodata":"","dot":false,"ymin":"","ymax":"","removeOlder":1,"removeOlderPoints":"","removeOlderUnit":"3600","cutout":0,"useOneColor":true,"useUTC":false,"colors":["#d73920","#ffcb13","#ff7f0e","#2ca02c","#98df8a","#d62728","#ff9896","#9467bd","#c5b0d5"],"outputs":1,"useDifferentColor":false,"className":"","x":570,"y":140,"wires":[[]]},{"id":"2d4fe667.28f8ba","type":"ui_group","name":"demo","tab":"1caa8458.b17814","order":1,"disp":true,"width":"12","collapse":false},{"id":"1caa8458.b17814","type":"ui_tab","name":"Demo","icon":"dashboard","order":1,"disabled":false,"hidden":false}]
Thank you for the example. It helped me a lot. Now the bar chart looks like it should. Is there actually a simple way to label the y-axis?
