CronPlus: disable syslog [info] entries
G'day y'all...
I am trying to find a way to disable all of the [info] log entries in the syslog file from the various cronplus nodes I have in my flows....
Anybody managed to do this? (If so.... How?)
Regds
Ed
Hi, i have an outstanding task to do that - my apologies it is not yet done
I will attempt to get this fixed soon
Oh wow!!
Thanks for the prompt comeback!!
I Luuuuurve cron plus btw!!
Cheers
Ed
I've got an open git issue for this, which I created in January.
In the meantime, I've edited cronplus.js and edited out these lines, so that they read;
            try {
                node.log(`createTask - index: ${index}, static: ${static}, opt: ${JSON.stringify(opt)}`);
            } catch (error) {
                node.error(error);
But of course my edit get's over-written each time I update Cron+, but it's a 2 minute job, and avoids the log getting polluted with information that I don't need to see.
[EDIT -] More replies whilst I was typing
[added by @zenofmud to make it easier for others to find the location of the code]
If you want to fix it you need to edit the cronplus.js file.
nano $HOME/.node-red/node_modules/node-red-contrib-cron-plus/cronplus.js
Then press ctrl-w (which is the keyboard shortcut for 'search) and enter function createTask to locate the code in the file to edit.
Then change the code to look like this:
        function createTask(node, opt, index, static) {
            opt = opt || {};
            try {
            } catch (error) {
                node.error(error);
            applyOptionDefaults(opt, index);
Save the file (ctrl-x then y then return) and reboot Node-RED
Thanks Paul,
That might just work for me in the interim...
Pray tell, can I just edit and save or must I restart something to get the changes "active"?
Regds
Ed
You just need to restart node-RED to read in the change.
Shotto!!
Will give it a go!!
Cheerz
E
Works a treat!!
Hopefully you will move the messages to debug or trace rather than removing them? They can occasionally be helpful after all :smiley:
