I am having a problem converting a Curl command to an HTTP Request on a Teltonika Router.
Hoping there is enough information here!
The Curl command is:-
curl -X POST "https://<ROUTERIP>/api/login" -H "Content-Type: application/json" -d `{"username": "<username>", "password": "<password>"}` -k
With a Verbose response of:-
Note: Unnecessary use of -X or --request, POST is already inferred.
* Trying v:443...
* Connected to <ROUTERIP> (<ROUTERIP>) port 443
* ALPN: curl offers h2,http/1.1
* TLSv1.3 (OUT), TLS handshake, Client hello (1):
* TLSv1.3 (IN), TLS handshake, Server hello (2):
* TLSv1.3 (IN), TLS handshake, Encrypted Extensions (8):
* TLSv1.3 (IN), TLS handshake, Certificate (11):
* TLSv1.3 (IN), TLS handshake, CERT verify (15):
* TLSv1.3 (IN), TLS handshake, Finished (20):
* TLSv1.3 (OUT), TLS change cipher, Change cipher spec (1):
* TLSv1.3 (OUT), TLS handshake, Finished (20):
* SSL connection using TLSv1.3 / TLS_CHACHA20_POLY1305_SHA256 / X25519 / id-ecPublicKey
* ALPN: server did not agree on a protocol. Uses default.
* Server certificate:
* subject: C=LT; ST=Vilnius; L=Vilnius; O=Teltonika9c3e02a3; CN=Teltonika
* start date: Mar 6 15:28:50 2025 GMT
* expire date: Mar 4 15:28:50 2035 GMT
* issuer: CN=ca
* SSL certificate verify result: unable to get local issuer certificate (20), continuing anyway.
* Certificate level 0: Public key type EC/prime256v1 (256/128 Bits/secBits), signed using sha256WithRSAEncryption
* using HTTP/1.x
> POST /api/login HTTP/1.1
> Host: <ROUTERIP>
> User-Agent: curl/8.5.0
> Accept: */*
> Content-Length: 67
* TLSv1.3 (IN), TLS handshake, Newsession Ticket (4):
* old SSL session ID is stale, removing
< HTTP/1.1 200 OK
< Connection: close
< Transfer-Encoding: chunked
< Expect-CT: max-age=86400
< Strict-Transport-Security: max-age=63072000; includeSubDomains; preload
< X-Frame-Options: SAMEORIGIN
< X-Content-Type-Options: nosniff
< Content-Security-Policy: default-src 'self'; frame-src * 'self'; img-src * 'self' data: blob:; script-src 'wasm-unsafe-eval' https://cdn.jsdelivr.net/ 'sha256-LV+4Blj3LIWsLHvvq37tdHwBQpq6ZOI+wHw3XeGsJzM=' 'self' 'sha256-8yE2w7Bv8/Il8SvtEkB35j3QNRei9CKtdX8HgqblU04=' 'sha256-Pv4HyWUIdh/mQalp8JMzRdM1eTkfzYhRRnW/9m4pzQ8=' 'sha256-/83V68bpILlL4sGTUJ9oviiw3La/Bskmmf83WaWOw9I=' blob:; style-src https://cdn.jsdelivr.net/ 'unsafe-hashes' 'sha256-4Su6mBWzEIFnH4pAGMOuaeBrstwJN4Z3pq/s1Kn4/KQ=' 'sha256-kwpt3lQZ21rs4cld7/uEm9qI5yAbjYzx+9FGm/XmwNU=' 'self'; connect-src 'self'; worker-src 'self' blob:; child-src 'self' blob:;
< Cache-Control: no-cache
< Access-Control-Allow-Origin: *
< Content-Type: application/json
* Closing connection
* TLSv1.3 (OUT), TLS alert, close notify (256):
{"success":true,"data":{"username":"admin","token":"<TOKEN>","expires":299}}
Trying to use the HTTP Request node, I get an UNABLE_TO_VERIFY_LEAF_SIGNATURE when injecting just the Payload (User/password).
In the Curl Command, I see SSL certificate verify result: unable to get local issuer certificate (20), continuing anyway. to overcome this I added msg.rejectUnauthorized = false in the Inject node. Now the I see requesting, and then after a time the HTTP Request node shows no response from server.
Flow
[{"id":"ef778648825337cb","type":"inject","z":"c17afc2be7cc5e34","name":"Payload and Reject Unauth","props":[{"p":"payload"},{"p":"rejectUnauthorized","v":"false","vt":"bool"}],"repeat":"","crontab":"","once":false,"onceDelay":"6","topic":"","payload":"{\"username\":\"<USERNAME\",\"password\":\"PASSWORD\"}","payloadType":"json","x":210,"y":260,"wires":[["38de799b1b6912aa","39e747f0b6789e32"]]},{"id":"38de799b1b6912aa","type":"http request","z":"c17afc2be7cc5e34","name":"fetch Token","method":"POST","ret":"txt","paytoqs":"ignore","url":"https://<ROUTERIP>/api/login","tls":"","persist":true,"proxy":"","insecureHTTPParser":false,"authType":"","senderr":false,"headers":[{"keyType":"Content-Type","keyValue":"","valueType":"application/json","valueValue":""},{"keyType":"other","keyValue":"Authorization","valueType":"other","valueValue":"Bearer <AUTH_TOKEN>"},{"keyType":"other","keyValue":"Content-length","valueType":"other","valueValue":"67"}],"x":490,"y":260,"wires":[["8e8e7e27668c91f3"]]},{"id":"8e8e7e27668c91f3","type":"debug","z":"c17afc2be7cc5e34","name":"Token","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"true","targetType":"full","statusVal":"","statusType":"auto","x":650,"y":260,"wires":[]},{"id":"39e747f0b6789e32","type":"debug","z":"c17afc2be7cc5e34","name":"Inputs","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"true","targetType":"full","statusVal":"","statusType":"auto","x":450,"y":300,"wires":[]},{"id":"72444f26261e574c","type":"inject","z":"c17afc2be7cc5e34","name":"Just Payload","props":[{"p":"payload"}],"repeat":"","crontab":"","once":false,"onceDelay":"6","topic":"","payload":"{\"username\":\"<USERNAME\",\"password\":\"PASSWORD\"}","payloadType":"json","x":170,"y":300,"wires":[["39e747f0b6789e32","38de799b1b6912aa"]]}]
Tried all sorts of things and now I class myself as 'Officially Stuck', not sure where to turn next!
Any help would be gratefully received.
TIA
Best wishes,
Colin J
