How to solve HTTP - Request error
I have a issue with solving HTTP-request error
using following request in the browser returns a usable data string
https://192.168.0.74:1443/api/config/flags
But in node red there are alarms I can't solve
For example with this version I got ECONNRESET error
debug window:
It would be helpful if you names all your nodes. That way the name will showup in the dwbug log instead of an ID
The unexpected token message probable comes from the json node telling you the data sent to it is bad. Add a debug node (set to display the complete msg object) to the the output of the http to show what it is getting.
I added names and a debug node. Looks like the issue is with unable to verify the first certificate?
Why it works in the browser??
Here the output from the browser
here the http request
Info if set to display complete msg object
Looking at the url from the screenshot you shared it seems that you are using a self signed certificate ?
The following from the http request nodes Help tab :
so set in your Http request node the url to be https:// ... (in the first screenshot you had it http)
and also the above option msg.rejectUnauthorized = false (set from the Inject node)
yeah, I tryed both as i don't understand the issue
Is that using msg.payload? and which type?
I tried a few combination but no success
I saw that you were triggering the http request from an Inject node so have you tried this
I tried like in the pic but it say invalid property expression
that must be for the msg.topic field that you have not set correctly and its highlighted in red.
just press X to remove the topic row (or fill it with a valid value if you need to)
sorry...
i got it to work (see picture) but same result in the http request
nope its not correct
node-red nodes expect their msg. properties and values to be very specific
does that look like the image i shared above ? :face_with_monocle:
If you are new to node-red, watch this video playlist for gettting started with the basics
Node-RED Essentials
I'm so sorry and thanks for the pation. now it passes !! You made my day :grinning:
Hi this is Palak Sharma.
Well for this you can clear your browser cookies with clearing DNS cache.
It may resolver your problem, if still have this problem or will come in future you must try it.
