UPDATE / Resolved: Upgraded to 3.1 - http request nodes are now giving ERR_TLS_CERT_ALTNAME_INVALID error. Rolled back to 3.0, error is gone
@TotallyInformation Finally figured this one out, and wanted to share the resolution!
Because an older palette I had installed was using an older version of agent-base, it was breaking the http-response node. Which meant that it was only getting responses from my OWN nginx server.
I cleared out a bunch of unused palette (I suspect the culprit was an old mqtt one...), restarted my docker container and viola - it works again.
The reason it worked in 3.0 vs 3.1 is that in 3.0 it used to "fix" it. Now it doesn't, which I suppose it a good thing. :slight_smile: Anyways, thanks for all the help talking it out!
Patched https.request function detected. This will break the
HTTP Request node. The original code has now been restored.
This is likely caused by a contrib node including an old version of
the 'agent-base@<5.0.0' module.
You can identify what node is at fault by running:
   npm list agent-base
in your Node-RED user directory (/data).
