I have a Max BR1 mini that I would like to communicate with and grab some data. The API works off of a HTTP request (Get and POST) I am sending a POST command to login and I am getting back an error:
"RequestError: Hostname/IP does not match certificate's altnames: IP: 192.168.0.1 is not in the cert's list: : https://192.168.0.1"
I think that I might have the configuration of the HTTP node incorrectly. Here is a screenshot of what I have so far:
Thank you I was able to figure it out and on one command, i was able to Post a login. The login is suppose to return a cookie and a status (which I got both) now, when I use a GET command, it fails as a 401. I am not sure what I am forgetting in my setup that could cause this error
