Current State false not working
I'm trying to create an automation where when I press a button I toggle 2 lights. This is easily done. However, if one is on and the other isn't, my switch toggles them back and forth.
so in node-red I go... and I come up with this flow... but it's not working. after about a good 30 minutes, I notice that my automation never goes through the "false" route from my 1st "current state"
if you have a look at my picture, current state for "Dan's bulb off?" True will go, but the False never reaches "Mimi's bulb on" regardless of the bulb is on or off.
am I doing something wrong? or not understanding how it works?
I've only had node-red for a week now.
[{"id":"8a52a161.b460a","type":"api-current-state","z":"ea71e47f.67eb18","name":"Dan bulb's in OFF?","server":"cd7bc65d.3014a8","version":1,"outputs":2,"halt_if":"off","halt_if_type":"str","halt_if_compare":"is","override_topic":false,"entity_id":"light.dan_s_bedroom_lamp_bulb","state_type":"str","state_location":"payload","override_payload":"msg","entity_location":"data","override_data":"msg","blockInputOverrides":false,"x":1210,"y":360,"wires":[["937c9fe5.da5ce"],["90e4bd9d.37c72"]]},{"id":"937c9fe5.da5ce","type":"api-current-state","z":"ea71e47f.67eb18","name":"Mimi bulb's in OFF?","server":"cd7bc65d.3014a8","version":1,"outputs":2,"halt_if":"off","halt_if_type":"str","halt_if_compare":"is","override_topic":false,"entity_id":"light.mimi_s_bedroom_lamp_bulb","state_type":"str","state_location":"payload","override_payload":"msg","entity_location":"data","override_data":"msg","blockInputOverrides":false,"x":1460,"y":320,"wires":[["4963e078.e1cdb","8c3e9bc6.eb7308"],["4963e078.e1cdb"]]},{"id":"90e4bd9d.37c72","type":"api-current-state","z":"ea71e47f.67eb18","name":"Mimi bulb's in ON?","server":"cd7bc65d.3014a8","version":1,"outputs":2,"halt_if":"on","halt_if_type":"str","halt_if_compare":"is","override_topic":false,"entity_id":"light.mimi_s_bedroom_lamp_bulb","state_type":"str","state_location":"payload","override_payload":"msg","entity_location":"data","override_data":"msg","blockInputOverrides":false,"x":1450,"y":400,"wires":[["8c3e9bc6.eb7308","4963e078.e1cdb"],["8c3e9bc6.eb7308"]]},{"id":"4963e078.e1cdb","type":"api-call-service","z":"ea71e47f.67eb18","name":"Mimi bulb Toggle","server":"cd7bc65d.3014a8","version":1,"debugenabled":false,"service_domain":"light","service":"toggle","entityId":"light.mimi_s_bedroom_lamp_bulb","data":"","dataType":"json","mergecontext":"","output_location":"","output_location_type":"none","mustacheAltTags":false,"x":1830,"y":400,"wires":[[]]},{"id":"8c3e9bc6.eb7308","type":"api-call-service","z":"ea71e47f.67eb18","name":"dan bulb Toggle","server":"cd7bc65d.3014a8","version":1,"debugenabled":false,"service_domain":"light","service":"toggle","entityId":"light.dan_s_bedroom_lamp_bulb","data":"","dataType":"json","mergecontext":"","output_location":"","output_location_type":"none","mustacheAltTags":false,"x":1800,"y":300,"wires":[[]]},{"id":"cd7bc65d.3014a8","type":"server","z":"","name":"Home Assistant","legacy":false,"addon":true,"rejectUnauthorizedCerts":true,"ha_boolean":"y|yes|true|on|home|open","connectionDelay":true,"cacheJson":false}]
Add debug nodes to find out which node is not working as you expect. Give the debug nodes names so it is easier to read the debug panel.
