Hi
I´m having a problem with this Flow. It was working well in Home Assistant before the last update. Now it isn´t working properly.
This is my flow:
And this is how should work:
- With a single click of Aqara switch the Bedroom Table toggle. This work ok
- With a double click of Aqara Switch the flow should switch ON the bedroom and Sinfonier lights if Sinfonier light is ON, or switch OFF the bedroom and Sinfonier lights if Sinfonier light is OFF. This is not working
The problem that I see is that I´m not able to see the state of Sinfonier Light with the node "Current State", that node only see the state of Aqara Switch, Why?, it was working before.
This is the node Sinfonier state
Best regards
[{"id":"2b7d9160.2d81fe","type":"server-events","z":"d783c4b2.959d28","name":"Click Aqara","server":"6355ba6b.3c7634","event_type":"xiaomi_aqara.click","x":410,"y":820,"wires":[["7db78dee.ba5054"]]},{"id":"7db78dee.ba5054","type":"switch","z":"d783c4b2.959d28","name":"Which Switch?","property":"payload.entity_id","propertyType":"msg","rules":[{"t":"eq","v":"binary_sensor.switch_158d00016be082","vt":"str"},{"t":"eq","v":"binary_sensor.switch_158d00018b4e17","vt":"str"},{"t":"eq","v":"binary_sensor.switch_158d0001b19ae3","vt":"str"},{"t":"eq","v":"binary_sensor.switch_158d0001e18e62","vt":"str"}],"checkall":"true","repair":false,"outputs":4,"x":620,"y":820,"wires":[[],["c901028e.38308"],[],[]]},{"id":"c901028e.38308","type":"switch","z":"d783c4b2.959d28","name":"Type of Click?","property":"payload.event.click_type","propertyType":"msg","rules":[{"t":"eq","v":"single","vt":"str"},{"t":"eq","v":"double","vt":"str"},{"t":"eq","v":"long_click_press","vt":"str"}],"checkall":"true","repair":false,"outputs":3,"x":900,"y":820,"wires":[["4085882f.83e378"],["8cc79ad0.448d58"],[]],"inputLabels":["Sinfonier"],"outputLabels":["Single","Double","Long"]},{"id":"4085882f.83e378","type":"api-call-service","z":"d783c4b2.959d28","name":"Toggle Bedroom Table","server":"6355ba6b.3c7634","service_domain":"light","service":"toggle","data":"{\"entity_id\":\"light.yeelight_color1_34ce00824cdf\",\"transition\":\"1\"}","mergecontext":"","output_location":"","output_location_type":"none","x":1240,"y":700,"wires":[[]]},{"id":"40734f94.ae907","type":"api-call-service","z":"d783c4b2.959d28","name":"Switch On Bedroom Table","server":"6355ba6b.3c7634","service_domain":"light","service":"turn_on","data":"{\"entity_id\":\"light.yeelight_color1_34ce00824cdf\",\"transition\":\"1\"}","mergecontext":"","output_location":"","output_location_type":"none","x":1760,"y":800,"wires":[["742188bf.bad6e8"]]},{"id":"6bc5aed6.fb0c5","type":"api-call-service","z":"d783c4b2.959d28","name":"Switch Off Bedroom Table","server":"6355ba6b.3c7634","service_domain":"light","service":"turn_off","data":"{\"entity_id\":\"light.yeelight_color1_34ce00824cdf\",\"transition\":\"1\"}","mergecontext":"","output_location":"","output_location_type":"none","x":1770,"y":1020,"wires":[["22ac40.8ce8c3c"]]},{"id":"742188bf.bad6e8","type":"api-call-service","z":"d783c4b2.959d28","name":"Switch On Sinfonier Table","server":"6355ba6b.3c7634","service_domain":"light","service":"turn_on","data":"{\"entity_id\":\"light.yeelight_color1_34ce0084675c\"}","mergecontext":"","output_location":"","output_location_type":"none","x":2010,"y":800,"wires":[[]]},{"id":"22ac40.8ce8c3c","type":"api-call-service","z":"d783c4b2.959d28","name":"Switch Off Sinfonier Table","server":"6355ba6b.3c7634","service_domain":"light","service":"turn_off","data":"{\"entity_id\":\"light.yeelight_color1_34ce0084675c\",\"transition\":\"1\"}","mergecontext":"","output_location":"","output_location_type":"none","x":2030,"y":1020,"wires":[[]]},{"id":"f9bf57d6.220198","type":"switch","z":"d783c4b2.959d28","name":"Change Bedroom and Sinfonier Table","property":"payload","propertyType":"msg","rules":[{"t":"eq","v":"off","vt":"str"},{"t":"eq","v":"on","vt":"str"}],"checkall":"true","repair":false,"outputs":2,"x":1430,"y":940,"wires":[["40734f94.ae907"],["6bc5aed6.fb0c5"]]},{"id":"8cc79ad0.448d58","type":"api-current-state","z":"d783c4b2.959d28","name":"Sinfonier State?","server":"6355ba6b.3c7634","outputs":1,"halt_if":"","halt_if_type":"str","halt_if_compare":"is","override_topic":true,"entity_id":"light.yeelight_color1_34ce0084675c","state_type":"str","state_location":"payload","override_payload":"msg","entity_location":"data","override_data":"msg","x":1160,"y":940,"wires":[["f9bf57d6.220198"]]},{"id":"409c0659.911918","type":"comment","z":"d783c4b2.959d28","name":"Single Click","info":"","x":1110,"y":800,"wires":[]},{"id":"49a5e86b.3b1268","type":"comment","z":"d783c4b2.959d28","name":"Double Click","info":"","x":1110,"y":880,"wires":[]},{"id":"6355ba6b.3c7634","type":"server","z":"","name":"Home Assistant"}]
