Custom UI node translation
I am currently trying to translate my custom UI node and there are some things that I just can't figure out.
  1. How do I add translation to the nodes defaults in myNode.html? The following does not work:
defaults: {
            devices: {value: [RED._("time-scheduler.ui.device")]},
            outputs: {value: 2},
"devices " should be an array containing one string.
  1. I also added translation to myNode.js, using:
RED._("myNode.myText")
This works fine for English but it also displays everything in English (locales/en-US/myNode.json) if the device should receive German (locales/DE/myNode.json) translations. Backend translations to German from the same file are working well though.
  1. What is the preferred way to add i18n support to a UI nodes scope?
I just released an update of my contrib-ui-node and wanted to share the github code so that everyone can see what I mean.
1 - how would I translate "Device1":
2 - whole UI only translates to EN:
3 - works but probably not the best solution
