Hi.
Have installed Node-red on a windows macine.
Trying for example to change the favicon. No problen on linux but can´t get it to work in windows.
Have edited this in settings.js
favicon: "C:\Users\Admin\.node-red\favicon.ico",
Do i need to change something else?
also tried to chande httpStatic: 'C:\Users\Admin\.node-red',
any idéa?
Regards Niclas
Try changing the path to use / rather than \:
"C:/Users/Admin/.node-red/favicon.ico"
Works better!! But it only worked in the workspace. Not in the dashboard.
Is it possible to also set favicon i dashboard?
The dashboard picks up its icons from it's /dist folder typically .node-red/node_modules/node-red-dashboard/dist - but it will get overwritten if/when you upgrade versions
