Change favicon in Node Red
How I can I change the favicon in the Node Red site ?
That’s currently not easy to do. You can replace the images in the dist folder but they may get overwritten on an upgrade unless you save them.
Did any easier way surface for changing favicon yet?
When we were still on Google Groups - below was posted:
How can I provide a custom favicon and a custom logo for my dashboard?
Right now the simplest way is to replace the icons in your ~/.node-red/node_modules/node-
red-dashboard/dist directory… and then edit the dashboard.appcache to also point to the new files.
https://groups.google.com/forum/?hl=en-GB#!topic/node-red/nJ_UKETxtIo
Allright folks i changed the icon in the node-red-dashboard/dist (smthing like that) folder and it didnt worked at the first try because i didnt clear the cache on my phone. I cleared the cache and i did "add to homescreen" again and it looked the way a wanted to. The .png file to modify is named icon64x64.png or icon192x192.png and i believe if you are iOS youll need to add an icon120x120.png in the same directory
~/.node-red/node_modules/node-red-dashboard/dist
The iOS icon size info is listed here https://developer.apple.com/library/content/documentation/AppleApplications/Reference/SafariWebContent/ConfiguringWebApplications/ConfiguringWebApplications.html
no. nothing has changed.
Why not just use the template node?
        "id": "5439e2fa04d0ab12",
        "type": "ui_template",
        "z": "ffc0171904d07147",
        "group": "40347547aa3cd9fd",
        "name": "favicon",
        "order": 1,
        "width": 0,
        "height": 0,
        "format": "<link rel=\"icon\" type=\"image/x-icon\" href=\"https://external-content.duckduckgo.com/ip3/nodered.org.ico\">",
        "storeOutMessages": true,
        "fwdInMessages": true,
        "resendOnRefresh": true,
        "templateScope": "global",
        "className": "",
        "x": 120,
        "y": 40,
        "id": "40347547aa3cd9fd",
        "type": "ui_group",
        "name": "Styles",
        "tab": "3e782fdfa1feb5fa",
        "order": 1,
        "disp": false,
        "width": "6",
        "collapse": false,
        "className": ""
        "id": "3e782fdfa1feb5fa",
        "type": "ui_tab",
        "name": "Styles",
        "icon": "dashboard",
        "order": 3,
        "disabled": false,
        "hidden": false
