I have been using the interface I created with Gauge classic on dashboard 2 for a few months. After the dashboard and gauge update, their old layouts are broken and I cannot create a similar interface using the same or another gauge. Are there any new settings I need to make other than the previous settings?
Welcome to the forum @Sirri.
Please select the gauges in the flow and use Menu > Export (or CTRL+E) to export to the clipboard and paste the result here. In order to make flow importable it is necessary to surround your code with three backticks (also known as a left quote or backquote ```)
flow goes here
We don't anything other than the gauge nodes.
If you have a CSS template to style the gauges please include that too.
Have you solved your problem @Sirri?
