Dashboard bar chart data node not working, error
I am trying to use this node to display a chart that has my usage data but the chart displays nothing and i get the following message in the debug:
"Error: Invalid property expression: unexpected ' ' at position 14"
here is what I have for testing:
        "id": "841f709cfbf9de7f",
        "type": "inject",
        "z": "f672d0ac69fd5b97",
        "props": [
                "p": "payload"
        "repeat": "",
        "crontab": "",
        "once": false,
        "onceDelay": 0.1,
        "topic": "",
        "payload": "1",
        "payloadType": "num",
        "x": 990,
        "y": 380,
                "fc4e0b59e0d7bd22"
        "id": "4733e656fd184a6a",
        "type": "inject",
        "name": "start",
        "props": [
                "p": "payload"
        "repeat": "",
        "crontab": "",
        "once": false,
        "onceDelay": 0.1,
        "topic": "",
        "payload": "set_meter_value 53.75",
        "payloadType": "str",
        "x": 1010,
        "y": 440,
                "fc4e0b59e0d7bd22"
        "id": "1be6d39134f351ab",
        "type": "debug",
        "name": "debug 14",
        "active": true,
        "tosidebar": true,
        "console": false,
        "tostatus": true,
        "complete": "payload",
        "targetType": "msg",
        "statusVal": "payload",
        "statusType": "auto",
        "x": 1180,
        "y": 420,
        "id": "c6b4d4dedbb755bf",
        "type": "bar-chart-data",
        "name": "bar-chart-data",
        "x_interval": "minutes",
        "x_size": "30",
        "unit": "kwh",
        "precision": "1",
        "is_meter_reading": "True",
        "agg_by": "sum",
        "x": 1020,
        "y": 480,
                "0522bde4be469f65",
                "1be6d39134f351ab"
        "id": "0522bde4be469f65",
        "type": "ui_chart",
        "group": "8ee0bb75fa4e2113",
        "order": 13,
        "width": 0,
        "height": 0,
        "label": "Power usage",
        "chartType": "bar",
        "legend": "true",
        "xformat": "D/M",
        "interpolate": "linear",
        "nodata": "",
        "dot": false,
        "ymin": "0",
        "ymax": "24",
        "removeOlder": "30",
        "removeOlderPoints": "",
        "removeOlderUnit": "86400",
        "cutout": 0,
        "useOneColor": false,
        "useUTC": false,
        "colors": [
            "#1f77b4",
            "#aec7e8",
            "#ff7f0e",
            "#2ca02c",
            "#98df8a",
            "#d62728",
            "#ff9896",
            "#9467bd",
            "#c5b0d5"
        "outputs": 1,
        "useDifferentColor": false,
        "className": "",
        "x": 1030,
        "y": 520,
        "id": "fc4e0b59e0d7bd22",
        "type": "change",
        "name": "topic",
        "rules": [
                "t": "set",
                "p": "topic",
                "pt": "msg",
                "to": "kwh",
                "tot": "str"
        "action": "",
        "property": "",
        "from": "",
        "to": "",
        "reg": false,
        "x": 830,
        "y": 480,
                "c6b4d4dedbb755bf"
        "id": "8ee0bb75fa4e2113",
        "type": "ui_group",
        "name": "Main",
        "tab": "9d03c9290d696c27",
        "order": 1,
        "disp": false,
        "width": 6,
        "collapse": false,
        "className": ""
        "id": "9d03c9290d696c27",
        "type": "ui_tab",
        "name": "Solar Power Stats",
        "icon": "dashboard",
        "disabled": false,
        "hidden": false
I installed node-red-contrib-bar-chart-data on Node-red v3.0.2, node.js 16.20.2
Your flow gives no errors. No chart output either, but no error messages.
