Dashboard Browser Tab Title - Set from a variable
I'd like to use a variable to set the Browser's Title in it's tab. I know you can manually set it in dashboard settings, but that is not desired as I have numerous instances running (100+) at different locations.
Thank you in advance, for your reply!
You can probably use an environment variable eg ${title}. And set it outside of Node-RED
Not quite sure how that is implemented. I just want the browser tab to show the hostname instead of "Node-RED Dashboard" and I need to do it programmatically, not from the NR Theme setting.
Thank you for the response. Just a hand edit to the settings.js file works well enough for my use.
That's good news. So what change do you make in settings.js?
In settings.js, prior to the "module.exports = {" line, I added:
hostPart1 = "Host: ";
hostPart2 = require('os').hostname();
hostname = hostPart1 + hostPart2;
process.env.HOST_TITLE = hostname;
Then in Node-Red Dashboard "Site" tab, I just set it to: ${HOST_TITLE}.
I also find it useful to change the page heading on the editor by setting process.env.DEVICE and adding this immediately below editorTheme: {
header: {
title: process.env.DEVICE
I wish the editor and dashboard would default to showing the name of the flows file on the header!
Nice! But, now you got me going down another rabbit hole. I also added:
page: {
So now I get the device name in the browser tab. But, it also adds the suffix of ": IP address" . Wondering how I can drop/change the suffix. Any ideas?
TIA
Don't know, sorry. This is what I currently have. I like to see the IP address.
Yeah, I gave up. I don't spend too much time in the editor anyway. I use the editor on one host and then copy the flow files to all of the other clients once testing is complete.
