Can I somehow get the name set in dashboard Title field in to my flow?
What exactly do you mean by dashboard title? Where does this appear in the configuration?
If you set the title using external environment variable eg:
Then it will be available to you elsewhere as that environment variable.
Should work with the new global env vars in settings panel too right?
