Hello, I have three buttons that when pushed change their color and text. The issue is if you switch tabs then come back, the buttons only keep their color and data. You cannot see the text unless you completely refresh. I attached only a section of my project in case something about the rest of it caused this but it didn't' help. I have tried UI Control nodes and injects and nothing helps.
I do not have your custom nodes - but looking at the flow it just sends true or false
can you just replace them with inject nodes and remove all the database stuff etc as not required to trrouble shoot this
This is basically what's happening
"id": "1c4e24791c0bfe19",
"type": "subflow",
"name": "Button Colors",
"info": "",
"category": "",
"in": [
"x": 380,
"y": 280,
"id": "a38c689e7571586a"
"out": [
"x": 740,
"y": 280,
"id": "213455d2a0e9ada1",
"port": 0
"id": "7778cb95a2efe79c",
"port": 0
"env": [],
"meta": {},
"color": "#DDAA99"
"type": "change",
"z": "1c4e24791c0bfe19",
"rules": [
"t": "set",
"p": "payload",
"pt": "msg",
"to": "Press to Reschedule",
"tot": "str"
"t": "set",
"p": "color",
"pt": "msg",
"to": "BLUE",
"tot": "str"
"t": "set",
"p": "letters",
"pt": "msg",
"to": "WHITES",
"tot": "str"
"action": "",
"property": "",
"from": "",
"to": "",
"reg": false,
"x": 620,
"y": 260,
"id": "a38c689e7571586a",
"type": "switch",
"property": "payload",
"propertyType": "msg",
"rules": [
"t": "false"
"t": "true"
"checkall": "true",
"repair": false,
"outputs": 2,
"x": 470,
"y": 280,
"213455d2a0e9ada1"
"7778cb95a2efe79c"
"type": "change",
"rules": [
"t": "set",
"p": "payload",
"pt": "msg",
"to": "Press to Shutoff",
"tot": "str"
"t": "set",
"p": "color",
"pt": "msg",
"to": "RED",
"tot": "str"
"t": "set",
"p": "letters",
"pt": "msg",
"to": "WHITE",
"tot": "str"
"action": "",
"property": "",
"from": "",
"to": "",
"reg": false,
"x": 620,
"y": 300,
"id": "70aab2f8064489a4",
"type": "tab",
"label": "Flow 1",
"disabled": false,
"info": "",
"env": []
"id": "ed03f10fcc84f3e9",
"type": "ui_button",
"z": "70aab2f8064489a4",
"name": "Override 1",
"group": "8801e65fe62929e9",
"order": 3,
"width": 3,
"height": 1,
"passthru": false,
"label": "{{payload}}",
"tooltip": "",
"color": "WHITE",
"bgcolor": "{{color}}",
"className": "",
"icon": "",
"payload": "false",
"payloadType": "bool",
"topic": "topic",
"topicType": "msg",
"x": 570,
"y": 240,
"0243981469c81ea0"
"id": "912860035f6c2b38",
"name": "Override 2",
"order": 5,
"width": 3,
"height": 1,
"passthru": false,
"tooltip": "",
"color": "WHITE",
"className": "",
"icon": "",
"payload": "false",
"topic": "topic",
"topicType": "msg",
"x": 570,
"y": 340,
"8f6087d25a44f3fe"
"id": "c214e1150ae8bf2a",
"name": "Override 3",
"order": 7,
"width": 3,
"height": 1,
"passthru": false,
"tooltip": "",
"color": "WHITE",
"className": "",
"icon": "",
"payload": "false",
"topic": "topic",
"topicType": "msg",
"x": 570,
"y": 440,
"019893fe6650a278"
"id": "a41b5b7e798f3883",
"type": "ui_text",
"order": 2,
"width": 3,
"height": 1,
"label": "Shift 1. ",
"format": "{{msg.payload}}",
"layout": "row-center",
"className": "",
"x": 700,
"y": 280,
"id": "1eb0ee55a2a7617b",
"type": "function",
"func": "if(msg.payload == 1){\n msg.payload = \"Scheduled\";\n}\nif(msg.payload == 0){\n msg.payload = \"Shutoff by User\";\n}\nreturn msg;",
"outputs": 1,
"noerr": 0,
"initialize": "",
"finalize": "",
"libs": [],
"x": 560,
"y": 280,
"a41b5b7e798f3883"
"id": "94f6e34ea3248cbb",
"type": "ui_text",
"order": 4,
"width": 3,
"height": 1,
"label": "Shift 2. ",
"className": "",
"x": 700,
"y": 380,
"id": "3846bf495c4b4f3b",
"type": "function",
"outputs": 1,
"noerr": 0,
"initialize": "",
"finalize": "",
"libs": [],
"x": 560,
"y": 380,
"94f6e34ea3248cbb"
"id": "32b0fee942070501",
"type": "ui_text",
"order": 6,
"width": 3,
"height": 1,
"label": "Shift 3. ",
"className": "",
"x": 700,
"y": 480,
"id": "a2de1510cc54d5ea",
"type": "function",
"outputs": 1,
"noerr": 0,
"initialize": "",
"finalize": "",
"libs": [],
"x": 560,
"y": 480,
"32b0fee942070501"
"id": "7dbabb356d975126",
"type": "ui_text",
"order": 1,
"width": 6,
"height": 1,
"label": "Line 1 Status",
"format": "",
"className": "",
"x": 670,
"y": 200,
"id": "7864ebc2d7c64db2",
"type": "ui_form",
"label": "Reason for Shutdown",
"order": 8,
"width": 6,
"height": 1,
"options": [
"value": "reason",
"type": "multiline",
"required": false,
"rows": 2
"formValue": {
"reason": ""
"payload": "",
"submit": "submit",
"cancel": "cancel",
"topic": "topic",
"topicType": "msg",
"splitLayout": "",
"className": "",
"x": 440,
"y": 540,
"af85478b42e401a6",
"02793b56e6df41ec"
"id": "af85478b42e401a6",
"type": "debug",
"active": true,
"tosidebar": true,
"console": false,
"tostatus": false,
"complete": "false",
"statusVal": "",
"statusType": "auto",
"x": 670,
"y": 580,
"id": "02793b56e6df41ec",
"type": "influxdb out",
"influxdb": "4492212ee887a9a8",
"name": "InfluxOut",
"measurement": "S105 Reason for Shutdown",
"precision": "",
"retentionPolicy": "",
"database": "database",
"precisionV18FluxV20": "ms",
"retentionPolicyV18Flux": "",
"org": "SHILOH",
"bucket": "node",
"x": 660,
"y": 540,
"id": "0243981469c81ea0",
"type": "trigger",
"op1": "true",
"op2": "false",
"op1type": "bool",
"op2type": "bool",
"duration": "100",
"extend": false,
"overrideDelay": false,
"units": "ms",
"reset": "",
"bytopic": "all",
"topic": "topic",
"outputs": 1,
"x": 740,
"y": 240,
"1a21d573443cfb99"
"id": "490505e43afa5cd1",
"type": "subflow:1c4e24791c0bfe19",
"x": 410,
"y": 240,
"ed03f10fcc84f3e9"
"id": "3437a07730cae066",
"x": 410,
"y": 440,
"c214e1150ae8bf2a"
"id": "23052394ca5e8786",
"x": 410,
"y": 340,
"912860035f6c2b38"
"id": "8f6087d25a44f3fe",
"type": "trigger",
"op1": "true",
"op2": "false",
"op1type": "bool",
"op2type": "bool",
"duration": "100",
"extend": false,
"units": "ms",
"reset": "",
"bytopic": "all",
"topic": "topic",
"outputs": 1,
"x": 740,
"y": 340,
"daa9210d19382f84"
"id": "019893fe6650a278",
"type": "trigger",
"op1": "true",
"op2": "false",
"op1type": "bool",
"op2type": "bool",
"duration": "100",
"extend": false,
"units": "ms",
"reset": "",
"bytopic": "all",
"topic": "topic",
"outputs": 1,
"x": 740,
"y": 440,
"bb314e779dd6fcf0"
"id": "1a21d573443cfb99",
"type": "link out",
"mode": "link",
"links": [
"4a8256d8a80738a2"
"x": 885,
"y": 240,
"id": "4a8256d8a80738a2",
"type": "link in",
"links": [
"1a21d573443cfb99",
"7608806ec1fe36ea"
"x": 405,
"y": 280,
"490505e43afa5cd1",
"1eb0ee55a2a7617b"
"id": "daa9210d19382f84",
"type": "link out",
"mode": "link",
"links": [
"020dad7d6aecc9eb"
"x": 875,
"y": 340,
"id": "bb314e779dd6fcf0",
"type": "link out",
"mode": "link",
"links": [
"4ea93b404048cffb"
"x": 885,
"y": 440,
"id": "020dad7d6aecc9eb",
"type": "link in",
"links": [
"daa9210d19382f84",
"7608806ec1fe36ea"
"x": 385,
"y": 380,
"3846bf495c4b4f3b",
"23052394ca5e8786"
"id": "4ea93b404048cffb",
"type": "link in",
"links": [
"bb314e779dd6fcf0"
"x": 415,
"y": 480,
"a2de1510cc54d5ea",
"3437a07730cae066"
"id": "8801e65fe62929e9",
"type": "ui_group",
"name": "Test 1",
"tab": "61ff2df7bf0207d5",
"order": 1,
"disp": true,
"width": "6",
"collapse": false,
"className": ""
"id": "4492212ee887a9a8",
"type": "influxdb",
"hostname": "127.0.0.1",
"port": "8086",
"protocol": "http",
"name": "95566dd911071ee1",
"usetls": false,
"tls": "",
"influxdbVersion": "2.0",
"url": "http://192.168.0.103:8086",
"rejectUnauthorized": true
"id": "61ff2df7bf0207d5",
"type": "ui_tab",
"name": "Testing",
"icon": "dashboard",
"order": 5,
"disabled": false,
"hidden": false
Looks like you have blue text on blue background - try setting some different colors ![]()
The text is set to be white in the node. Whenever you switch tabs it decides to switch it to blue
It "seems" like a bug, but try this -
[{"id":"1c4e24791c0bfe19","type":"subflow","name":"Button Colors","info":"","category":"","in":[{"x":380,"y":280,"wires":[{"id":"a38c689e7571586a"}]}],"out":[{"x":740,"y":280,"wires":[{"id":"7778cb95a2efe79c","port":0},{"id":"213455d2a0e9ada1","port":0}]}],"env":[],"meta":{},"color":"#DDAA99"},{"id":"213455d2a0e9ada1","type":"change","z":"1c4e24791c0bfe19","name":"","rules":[{"t":"set","p":"payload","pt":"msg","to":"Press to Reschedule","tot":"str"},{"t":"set","p":"background","pt":"msg","to":"BLUE","tot":"str"},{"t":"set","p":"letters","pt":"msg","to":"WHITE","tot":"str"}],"action":"","property":"","from":"","to":"","reg":false,"x":620,"y":200,"wires":[[]]},{"id":"a38c689e7571586a","type":"switch","z":"1c4e24791c0bfe19","name":"","property":"payload","propertyType":"msg","rules":[{"t":"false"},{"t":"true"}],"checkall":"true","repair":false,"outputs":2,"x":470,"y":280,"wires":[["213455d2a0e9ada1"],["7778cb95a2efe79c"]]},{"id":"7778cb95a2efe79c","type":"change","z":"1c4e24791c0bfe19","name":"","rules":[{"t":"set","p":"payload","pt":"msg","to":"Press to Shutoff","tot":"str"},{"t":"set","p":"background","pt":"msg","to":"RED","tot":"str"},{"t":"set","p":"letters","pt":"msg","to":"WHITE","tot":"str"}],"action":"","property":"","from":"","to":"","reg":false,"x":620,"y":300,"wires":[[]]},{"id":"a66f1b3f296c819a","type":"ui_button","z":"48a03d21a513552e","name":"Override 1","group":"ef946bf742693233","order":3,"width":3,"height":1,"passthru":false,"label":"{{payload}}","tooltip":"","color":"{{letters}}","bgcolor":"{{background}}","className":"","icon":"","payload":"false","payloadType":"bool","topic":"topic","topicType":"msg","x":570,"y":240,"wires":[["065d594c01c1f31a"]]},{"id":"0a48c2fedd6de701","type":"ui_text","z":"48a03d21a513552e","group":"ef946bf742693233","order":2,"width":3,"height":1,"name":"","label":"Shift 1. ","format":"{{msg.payload}}","layout":"row-center","className":"","x":700,"y":280,"wires":[]},{"id":"e611e33ade371120","type":"function","z":"48a03d21a513552e","name":"","func":"if(msg.payload == 1){\n msg.payload = \"Scheduled\";\n}\nif(msg.payload == 0){\n msg.payload = \"Shutoff by User\";\n}\nreturn msg;","outputs":1,"noerr":0,"initialize":"","finalize":"","libs":[],"x":560,"y":280,"wires":[["0a48c2fedd6de701"]]},{"id":"776894f47ffcc84b","type":"ui_text","z":"48a03d21a513552e","group":"ef946bf742693233","order":1,"width":6,"height":1,"name":"","label":"Line 1 Status","format":"","layout":"row-center","className":"","x":670,"y":200,"wires":[]},{"id":"065d594c01c1f31a","type":"trigger","z":"48a03d21a513552e","name":"","op1":"true","op2":"false","op1type":"bool","op2type":"bool","duration":"1000","extend":false,"overrideDelay":false,"units":"ms","reset":"","bytopic":"all","topic":"topic","outputs":1,"x":740,"y":240,"wires":[["18430d5e312303df"]]},{"id":"512f55205d5b216a","type":"subflow:1c4e24791c0bfe19","z":"48a03d21a513552e","name":"","x":340,"y":240,"wires":[["a66f1b3f296c819a"]]},{"id":"18430d5e312303df","type":"link out","z":"48a03d21a513552e","name":"","mode":"link","links":["1f13c5a67e2c1976"],"x":885,"y":240,"wires":[]},{"id":"1f13c5a67e2c1976","type":"link in","z":"48a03d21a513552e","name":"","links":["18430d5e312303df","7608806ec1fe36ea"],"x":405,"y":280,"wires":[["512f55205d5b216a","e611e33ade371120"]]},{"id":"ef946bf742693233","type":"ui_group","name":"Test 1","tab":"4690873f461ac7f6","order":1,"disp":true,"width":"6","collapse":false,"className":""},{"id":"4690873f461ac7f6","type":"ui_tab","name":"Testing","icon":"dashboard","order":5,"disabled":false,"hidden":false}]
It looks like the msg.color is getting applied to the text after changing tabs.
@dceejay @knolleary Can you take a quick look at this issue ?
Button works ok until switching tabs then turns text to blue
[{"id":"1c4e24791c0bfe19","type":"subflow","name":"Button Colors","info":"","category":"","in":[{"x":380,"y":280,"wires":[{"id":"a38c689e7571586a"}]}],"out":[{"x":740,"y":280,"wires":[{"id":"7778cb95a2efe79c","port":0},{"id":"213455d2a0e9ada1","port":0}]}],"env":[],"meta":{},"color":"#DDAA99"},{"id":"213455d2a0e9ada1","type":"change","z":"1c4e24791c0bfe19","name":"","rules":[{"t":"set","p":"payload","pt":"msg","to":"Press to Reschedule","tot":"str"},{"t":"set","p":"color","pt":"msg","to":"BLUE","tot":"str"}],"action":"","property":"","from":"","to":"","reg":false,"x":620,"y":200,"wires":[[]]},{"id":"a38c689e7571586a","type":"switch","z":"1c4e24791c0bfe19","name":"","property":"payload","propertyType":"msg","rules":[{"t":"false"},{"t":"true"}],"checkall":"true","repair":false,"outputs":2,"x":470,"y":280,"wires":[["213455d2a0e9ada1"],["7778cb95a2efe79c"]]},{"id":"7778cb95a2efe79c","type":"change","z":"1c4e24791c0bfe19","name":"","rules":[{"t":"set","p":"payload","pt":"msg","to":"Press to Shutoff","tot":"str"},{"t":"set","p":"color","pt":"msg","to":"RED","tot":"str"}],"action":"","property":"","from":"","to":"","reg":false,"x":620,"y":300,"wires":[[]]},{"id":"a66f1b3f296c819a","type":"ui_button","z":"48a03d21a513552e","name":"Override 1","group":"ef946bf742693233","order":3,"width":3,"height":1,"passthru":false,"label":"{{payload}}","tooltip":"","color":"white","bgcolor":"{{color}}","className":"","icon":"","payload":"false","payloadType":"bool","topic":"topic","topicType":"msg","x":570,"y":240,"wires":[["065d594c01c1f31a"]]},{"id":"0a48c2fedd6de701","type":"ui_text","z":"48a03d21a513552e","group":"ef946bf742693233","order":2,"width":3,"height":1,"name":"","label":"Shift 1. ","format":"{{msg.payload}}","layout":"row-center","className":"","x":700,"y":280,"wires":[]},{"id":"e611e33ade371120","type":"function","z":"48a03d21a513552e","name":"","func":"if(msg.payload == 1){\n msg.payload = \"Scheduled\";\n}\nif(msg.payload == 0){\n msg.payload = \"Shutoff by User\";\n}\nreturn msg;","outputs":1,"noerr":0,"initialize":"","finalize":"","libs":[],"x":560,"y":280,"wires":[["0a48c2fedd6de701"]]},{"id":"776894f47ffcc84b","type":"ui_text","z":"48a03d21a513552e","group":"ef946bf742693233","order":1,"width":6,"height":1,"name":"","label":"Line 1 Status","format":"","layout":"row-center","className":"","x":670,"y":200,"wires":[]},{"id":"065d594c01c1f31a","type":"trigger","z":"48a03d21a513552e","name":"","op1":"true","op2":"false","op1type":"bool","op2type":"bool","duration":"1000","extend":false,"overrideDelay":false,"units":"ms","reset":"","bytopic":"all","topic":"topic","outputs":1,"x":740,"y":240,"wires":[["18430d5e312303df"]]},{"id":"512f55205d5b216a","type":"subflow:1c4e24791c0bfe19","z":"48a03d21a513552e","name":"","x":340,"y":240,"wires":[["a66f1b3f296c819a"]]},{"id":"18430d5e312303df","type":"link out","z":"48a03d21a513552e","name":"","mode":"link","links":["1f13c5a67e2c1976"],"x":885,"y":240,"wires":[]},{"id":"1f13c5a67e2c1976","type":"link in","z":"48a03d21a513552e","name":"","links":["18430d5e312303df","7608806ec1fe36ea"],"x":405,"y":280,"wires":[["512f55205d5b216a","e611e33ade371120"]]},{"id":"ef946bf742693233","type":"ui_group","name":"Test 1","tab":"4690873f461ac7f6","order":1,"disp":true,"width":"6","collapse":false,"className":""},{"id":"4690873f461ac7f6","type":"ui_tab","name":"Testing","icon":"dashboard","order":5,"disabled":false,"hidden":false}]
This works OK - using a different property name msg.background
try with just the flow I sent - also do a refresh after first deploy it works OK for me then
Yes that worked thank you
