Dashboard is blank
Any Body can help me? My dashboard is all withe! I dont have any contens inside and i dont know why!
I cannot find any problems on logs!
22 Jan 06:28:16 - [info]
Welcome to Node-RED
22 Jan 06:28:16 - [info] Node-RED version: v1.2.7
22 Jan 06:28:16 - [info] Node.js  version: v14.15.4
22 Jan 06:28:16 - [info] Linux 5.4.72-v7+ arm LE
22 Jan 06:28:17 - [info] Loading palette nodes
22 Jan 06:28:18 - [debug] Module: node-red-contrib-homeconnect 0.6.1
22 Jan 06:28:18 - [debug]         /home/pi/.node-red/node_modules/node-red-contrib-homeconnect
22 Jan 06:28:18 - [debug] Module: node-red-contrib-play-audio 2.5.0
22 Jan 06:28:18 - [debug]         /home/pi/.node-red/node_modules/node-red-contrib-play-audio
22 Jan 06:28:18 - [debug] Module: node-red-dashboard 2.27.0
22 Jan 06:28:18 - [debug]         /home/pi/.node-red/node_modules/node-red-dashboard
22 Jan 06:28:18 - [debug] Module: node-red-node-pi-gpio 1.2.3
22 Jan 06:28:18 - [debug]         /home/pi/.node-red/node_modules/node-red-node-pi-gpio
22 Jan 06:28:18 - [debug] Module: node-red-node-ping 0.2.2
22 Jan 06:28:18 - [debug]         /home/pi/.node-red/node_modules/node-red-node-ping
22 Jan 06:28:18 - [debug] Module: node-red-node-random 0.3.1
22 Jan 06:28:18 - [debug]         /home/pi/.node-red/node_modules/node-red-node-random
22 Jan 06:28:18 - [debug] Module: node-red-node-serialport 0.11.1
22 Jan 06:28:18 - [debug]         /home/pi/.node-red/node_modules/node-red-node-serialport
22 Jan 06:28:18 - [debug] Module: node-red-node-smooth 0.1.2
22 Jan 06:28:18 - [debug]         /home/pi/.node-red/node_modules/node-red-node-smooth
22 Jan 06:28:18 - [debug] Module: node-red-node-rbe 0.2.9
22 Jan 06:28:18 - [debug]         /usr/local/lib/node_modules/node-red/node_modules/node-red-node-rbe
22 Jan 06:28:18 - [debug] Module: node-red-node-tail 0.1.1
22 Jan 06:28:18 - [debug]         /usr/local/lib/node_modules/node-red/node_modules/node-red-node-tail
22 Jan 06:28:24 - [info] Dashboard version 2.27.0 started at /ui
22 Jan 06:28:24 - [info] Settings file  : /home/pi/.node-red/settings.js
22 Jan 06:28:24 - [info] Context store  : 'default' [module=memory]
22 Jan 06:28:24 - [info] User directory : /home/pi/.node-red
22 Jan 06:28:24 - [warn] Projects disabled : editorTheme.projects.enabled=false
22 Jan 06:28:24 - [info] Flows file     : /home/pi/.node-red/flows_domoticz-S01.json
22 Jan 06:28:25 - [info] Server now running at http://127.0.0.1:1880/
22 Jan 06:28:25 - [debug] loaded flow revision: 633b976769ad1b53bc4b4a9a53f1cf11
22 Jan 06:28:25 - [debug] red/runtime/nodes/credentials.load : user provided key
22 Jan 06:28:25 - [debug] red/runtime/nodes/credentials.load : default key present. Will migrate
22 Jan 06:28:25 - [debug] red/runtime/nodes/credentials.load : keyType=user
22 Jan 06:28:25 - [info] Starting flows
22 Jan 06:28:25 - [debug] red/nodes/flows.start : starting flow : global
22 Jan 06:28:25 - [debug] red/nodes/flows.start : starting flow : d5231c39.b55c8
22 Jan 06:28:25 - [debug] red/nodes/flows.start : not starting disabled flow : 8f10b1e.de97d5
22 Jan 06:28:25 - [debug] red/nodes/flows.start : starting flow : 26a1e310.57bcac
22 Jan 06:28:25 - [debug] red/nodes/flows.start : not starting disabled flow : c13ee041.02002
22 Jan 06:28:25 - [debug] red/nodes/flows.start : not starting disabled flow : fb684a80.214f48
22 Jan 06:28:25 - [debug] [flow:global] not starting disabled config node : 7686f54.6c3e90c
22 Jan 06:28:25 - [info] [home-connect-auth:Siemens EP] refreshing token...
22 Jan 06:28:25 - [debug] [flow:d5231c39.b55c8] not starting disabled node : cd57866e.724ce8
22 Jan 06:28:25 - [debug] [flow:d5231c39.b55c8] not starting disabled node : 8d18ffa0.d844a
22 Jan 06:28:25 - [debug] [flow:26a1e310.57bcac] not starting disabled node : 71b58c15.2fc554
22 Jan 06:28:25 - [debug] [flow:26a1e310.57bcac] not starting disabled node : 2be1bc27.e03474
22 Jan 06:28:25 - [info] Started flows
22 Jan 06:29:22 - [debug] [home-connect-event:2862a676.39e9ba] keep-alive received
Thanks for your help
Welcome to the forum.
Please clear the browser cache (via the browser menus) and do a full refresh of the page. If that doesn't fix it then open the browser developer console, refresh the page, and see if there are any errors.
Clear Cache has not solved issue!
Here the error on chrome console when i load the dashboard side tab :
vendor.js:4 JQMIGRATE: Migrate is installed, version 3.3.0
DevTools failed to load SourceMap: Could not load content for http://192.168.5.5:1880/vendor/purify.min.js.map: HTTP error: status code 404, net::ERR_HTTP_RESPONSE_CODE_FAILURE
VM2857:3 XHR Loaded (theme - 200 OK - 12.498000054620206ms - 490B)
VM2861:3 XHR Loaded (editor - 200 OK - 21.20600000489503ms - 267B)
VM2865:3 XHR Loaded (node-red - 200 OK - 35.82099999766797ms - 267B)
VM2869:3 XHR Loaded (node-red - 200 OK - 43.16400003153831ms - 23.932KB)
VM2873:3 XHR Loaded (jsonata - 200 OK - 49.384000012651086ms - 267B)
VM2877:3 XHR Loaded (editor - 200 OK - 60.72700000368059ms - 38.392KB)
VM2881:3 XHR Loaded (jsonata - 200 OK - 65.76799997128546ms - 17.043KB)
VM2885:3 XHR Loaded (infotips - 200 OK - 67.5760000012815ms - 267B)
VM2889:3 XHR Loaded (infotips - 200 OK - 70.2809999929741ms - 2.014KB)
red.min.js:16 Node-RED: 1.2.7
red.min.js:16 Versions
VM2893:3 XHR Loaded (settings - 200 OK - 17.253999947570264ms - 523B)
370[Violation] Added non-passive event listener to a scroll-blocking <some> event. Consider marking event handler as 'passive' to make the page more responsive. See <URL>
red.min.js:16 Projects disabled
vendor.js:2 [Violation] 'load' handler took 582ms
VM2897:3 XHR Loaded (user - 200 OK - 19.76900000590831ms - 459B)
VM2901:3 XHR Loaded (keymap.json - 304 Not Modified - 12.196999974548817ms - 308B)
VM2905:3 XHR Loaded (nodes - 200 OK - 26.18899999652058ms - 9.946KB)
VM2909:3 XHR Loaded (messages - 200 OK - 37.90700004901737ms - 1.426KB)
VM2913:3 XHR Loaded (messages - 200 OK - 52.51499998848885ms - 13.104KB)
VM2917:3 XHR Loaded (icons - 200 OK - 10.614999919198453ms - 1.401KB)
VM2922:3 XHR Loaded (nodes - 200 OK - 140.5139999696985ms - 851.084KB)
red.min.js:16 [Violation] 'load' handler took 586ms
[Violation] Forced reflow while executing JavaScript took 60ms
31[Violation] 'setTimeout' handler took <N>ms
red.min.js:16 Definition error: ui_button.label TypeError: Cannot read property 'indexOf' of undefined
    at Object.label (<anonymous>:36:62)
    at h (red.min.js:16)
    at g (red.min.js:16)
    at C (red.min.js:16)
    at Object.emit (red.min.js:16)
    at ge (red.min.js:16)
    at Object.v [as import] (red.min.js:16)
    at Object.success (red.min.js:16)
    at c (vendor.js:2)
    at Object.fireWith [as resolveWith] (vendor.js:2)
    at Object.getNodeLabel (red.min.js:16)
    at c (red.min.js:16)
    at m (red.min.js:16)
    at c (vendor.js:2)
    at c (vendor.js:2)
    at c (vendor.js:2)
    at c (vendor.js:2)
    at c (vendor.js:2)
    at c (vendor.js:2)
    at c (vendor.js:2)
    at c (vendor.js:2)
    at c (vendor.js:2)
    at c (vendor.js:2)
    at c (vendor.js:2)
    at c (vendor.js:2)
    at c (vendor.js:2)
    at c (vendor.js:2)
    at c (vendor.js:2)
red.min.js:16 Definition error: ui_chart.label TypeError: Cannot read property 'indexOf' of undefined
    at Object.label (<anonymous>:44:62)
    at c (vendor.js:2)
    at c (vendor.js:2)
    at c (vendor.js:2)
    at c (vendor.js:2)
    at c (vendor.js:2)
    at c (vendor.js:2)
    at c (vendor.js:2)
    at c (vendor.js:2)
    at c (vendor.js:2)
    at c (vendor.js:2)
    at c (vendor.js:2)
    at c (vendor.js:2)
vendor.js:2 [Violation] 'load' handler took 450ms
[Violation] Forced reflow while executing JavaScript took 44ms
8red.min.js:16 Definition error: ui_button.label TypeError: Cannot read property 'indexOf' of undefined
    at SVGGElement.<anonymous> (red.min.js:16)
    at vendor.js:37
    at Tn (vendor.js:35)
    at Array.Ma.each (vendor.js:37)
    at Tt (red.min.js:16)
6red.min.js:16 Definition error: ui_chart.label TypeError: Cannot read property 'indexOf' of undefined
    at vendor.js:37
red.min.js:16 [Violation] 'requestAnimationFrame' handler took 328ms
[Violation] Forced reflow while executing JavaScript took 52ms
VM3008:3 XHR Loaded (flows - 200 OK - 85.38099995348603ms - 59.521KB)
DevTools failed to load SourceMap: Could not load content for http://192.168.5.5:1880/gridstack.min.map: HTTP error: status code 404, net::ERR_HTTP_RESPONSE_CODE_FAILURE
VM3012:3 XHR Loaded (tinycolor-min.js - 304 Not Modified - 22.436999948695302ms - 316B)
VM3016:3 XHR Loaded (gridstack.min.js - 304 Not Modified - 28.26300007291138ms - 316B)
VM3020:3 XHR Loaded (uisettings - 304 Not Modified - 23.26099993661046ms - 218B)
VM3026:3 XHR Loaded (gridstack.jQueryUI.min.js - 304 Not Modified - 23.88500003144145ms - 314B)
VM2970:1931 Uncaught ReferenceError: d is not defined
    at Object.addItem (<anonymous>:1931:78)
    at t.<computed>.<computed>.insertItemAt (red.min.js:16)
    at t.<computed>.<computed>.insertItemAt (vendor.js:10)
    at t.<computed>.<computed>.addItem (red.min.js:16)
    at t.<computed>.<computed>.addItem (vendor.js:10)
    at HTMLOListElement.<anonymous> (vendor.js:10)
    at Function.each (vendor.js:2)
    at s.fn.init.each (vendor.js:2)
    at s.fn.init.t.fn.<computed> [as editableList] (vendor.js:10)
    at handlePendingAdds (<anonymous>:2648:60)
addItem @ VM2970:1931
insertItemAt @ red.min.js:16
(anonymous) @ vendor.js:10
addItem @ red.min.js:16
each @ vendor.js:2
each @ vendor.js:2
t.fn.<computed> @ vendor.js:10
handlePendingAdds @ VM2970:2648
setTimeout (async)
handlePendingAdds @ VM2970:2644
setTimeout (async)
handlePendingAdds @ VM2970:2632
setTimeout (async)
nodesAddEventHandler @ VM2970:2672
emit @ red.min.js:16
ge @ red.min.js:16
v @ red.min.js:16
success @ red.min.js:16
c @ vendor.js:2
fireWith @ vendor.js:2
l @ vendor.js:2
(anonymous) @ vendor.js:2
load (async)
send @ vendor.js:2
ajax @ vendor.js:2
s.ajax @ vendor.js:4
a @ red.min.js:16
i @ red.min.js:16
r @ red.min.js:16
i @ red.min.js:16
r @ red.min.js:16
i @ red.min.js:16
r @ red.min.js:16
i @ red.min.js:16
r @ red.min.js:16
i @ red.min.js:16
r @ red.min.js:16
i @ red.min.js:16
r @ red.min.js:16
i @ red.min.js:16
r @ red.min.js:16
i @ red.min.js:16
r @ red.min.js:16
i @ red.min.js:16
r @ red.min.js:16
i @ red.min.js:16
r @ red.min.js:16
i @ red.min.js:16
r @ red.min.js:16
i @ red.min.js:16
r @ red.min.js:16
i @ red.min.js:16
r @ red.min.js:16
i @ red.min.js:16
r @ red.min.js:16
i @ red.min.js:16
r @ red.min.js:16
i @ red.min.js:16
r @ red.min.js:16
i @ red.min.js:16
r @ red.min.js:16
i @ red.min.js:16
r @ red.min.js:16
i @ red.min.js:16
r @ red.min.js:16
i @ red.min.js:16
r @ red.min.js:16
i @ red.min.js:16
r @ red.min.js:16
i @ red.min.js:16
r @ red.min.js:16
i @ red.min.js:16
r @ red.min.js:16
i @ red.min.js:16
r @ red.min.js:16
i @ red.min.js:16
r @ red.min.js:16
i @ red.min.js:16
r @ red.min.js:16
i @ red.min.js:16
r @ red.min.js:16
i @ red.min.js:16
r @ red.min.js:16
i @ red.min.js:16
r @ red.min.js:16
i @ red.min.js:16
r @ red.min.js:16
i @ red.min.js:16
r @ red.min.js:16
i @ red.min.js:16
r @ red.min.js:16
i @ red.min.js:16
r @ red.min.js:16
i @ red.min.js:16
r @ red.min.js:16
i @ red.min.js:16
r @ red.min.js:16
i @ red.min.js:16
r @ red.min.js:16
i @ red.min.js:16
r @ red.min.js:16
i @ red.min.js:16
r @ red.min.js:16
i @ red.min.js:16
r @ red.min.js:16
i @ red.min.js:16
r @ red.min.js:16
i @ red.min.js:16
r @ red.min.js:16
i @ red.min.js:16
r @ red.min.js:16
i @ red.min.js:16
r @ red.min.js:16
i @ red.min.js:16
r @ red.min.js:16
i @ red.min.js:16
r @ red.min.js:16
i @ red.min.js:16
r @ red.min.js:16
i @ red.min.js:16
r @ red.min.js:16
i @ red.min.js:16
r @ red.min.js:16
i @ red.min.js:16
r @ red.min.js:16
i @ red.min.js:16
r @ red.min.js:16
i @ red.min.js:16
r @ red.min.js:16
i @ red.min.js:16
r @ red.min.js:16
i @ red.min.js:16
r @ red.min.js:16
i @ red.min.js:16
r @ red.min.js:16
i @ red.min.js:16
r @ red.min.js:16
i @ red.min.js:16
r @ red.min.js:16
i @ red.min.js:16
r @ red.min.js:16
i @ red.min.js:16
r @ red.min.js:16
i @ red.min.js:16
r @ red.min.js:16
i @ red.min.js:16
r @ red.min.js:16
i @ red.min.js:16
r @ red.min.js:16
i @ red.min.js:16
r @ red.min.js:16
i @ red.min.js:16
r @ red.min.js:16
i @ red.min.js:16
r @ red.min.js:16
i @ red.min.js:16
i.test.onload @ red.min.js:16
load (async)
(anonymous) @ red.min.js:16
each @ vendor.js:2
each @ vendor.js:2
r @ red.min.js:16
i @ red.min.js:16
r @ red.min.js:16
i @ red.min.js:16
c @ vendor.js:2
l @ vendor.js:2
load (async)
send @ vendor.js:2
ajax @ vendor.js:2
t @ red.min.js:16
c @ vendor.js:2
l @ vendor.js:2
load (async)
send @ vendor.js:2
ajax @ vendor.js:2
s @ red.min.js:16
c @ vendor.js:2
l @ vendor.js:2
load (async)
send @ vendor.js:2
ajax @ vendor.js:2
loadNodeCatalogs @ red.min.js:16
c @ vendor.js:2
l @ vendor.js:2
load (async)
send @ vendor.js:2
ajax @ vendor.js:2
d @ red.min.js:16
c @ vendor.js:2
l @ vendor.js:2
load (async)
send @ vendor.js:2
ajax @ vendor.js:2
t @ red.min.js:16
c @ vendor.js:2
l @ vendor.js:2
load (async)
send @ vendor.js:2
ajax @ vendor.js:2
a @ red.min.js:16
init @ red.min.js:16
(anonymous) @ vendor.js:42
g @ vendor.js:42
success @ vendor.js:42
c @ vendor.js:2
l @ vendor.js:2
load (async)
send @ vendor.js:2
ajax @ vendor.js:2
_fetchOne @ vendor.js:42
each @ vendor.js:2
each @ vendor.js:2
_fetch @ vendor.js:42
load @ vendor.js:42
g @ vendor.js:42
(anonymous) @ main.min.js:16
e @ vendor.js:2
t @ vendor.js:2
setTimeout (async)
c @ vendor.js:2
fire @ vendor.js:2
c @ vendor.js:2
ready @ vendor.js:2
B @ vendor.js:2
Show 125 more frames
    at <anonymous>:2008:40
each @ vendor.js:2
each @ vendor.js:2
(anonymous) @ VM2970:2008
addItem @ VM2970:2007
each @ vendor.js:2
each @ vendor.js:2
(anonymous) @ VM2970:2063
addTabOrLinkItem @ VM2970:2062
each @ vendor.js:2
each @ vendor.js:2
(anonymous) @ VM2970:2365
refresh @ VM2970:2364
onchange @ VM2970:2500
onchange @ red.min.js:16
R @ red.min.js:16
onselect @ red.min.js:16
c @ red.min.js:16
dispatch @ vendor.js:2
v.handle @ vendor.js:2
Show 9 more frames
That is a warning, so no need to worry about that
That appears to be the problem.
What do you mean by loading the side tab?
The red circle is usually where i can to change order of controls of my uidashboard. I cannot see it!
Understood.
I see you have some disabled flows and nodes, I wonder whether that could be related to the issues. Can you try enabling all those and see if it works?
Also was it working at one point and then stopped? If so what did you do at that time?
Never worked i think! i'm just start with this and im not familiary with nodered mecanism! I think never worked! this flow is imported flok from another user! i just get it because is a first one to help me undersanding things of nodered! I try to crar cache, reboot server service, reboot all Rpi, enable all flows and the structure in never displayed. Any other way to edit dashboard pages like buttons orther etc...?
That seems to be in conflict with something you said earlier
Which suggests that you have had a working system.
If you just want to start again then rename the .node-red folder to something else and restart node-red and you will start again with a clean system.
As you are a beginner I suggest watching this playlist: Node-RED Essentials. The videos are done by the developers of node-red. They're nice & short and to the point. You will understand a whole lot more in about 1 hour. A small investment for a lot of gain.
