Dashboard Template
I want to make dashboard template node.
When I gave a data, automatic make template. It is impossible?
This is my template. The value is continually added every time new data comes in. Then I want to keep adding a small circle next to it.
<table  layout="row" layout-align="start center" id="table" border="0.5" cellpadding="15">
 <tbody>
 <tr>
 <th>ADDR</th>
 </tr>
     <tr ng-repeat="row1 in msg.addr track by $index">
      <td ng-class="numeric" >{{row1}}</td>
      </tr>
 </tbody>
 <tbody>
 <tr>
 <th>TEST</th>
 </tr>
     <tr ng-repeat="row2 in msg.c_rate track by $index">
      <td ng-class="numeric" >{{row2}}</td>
      </tr>
 </tbody>
</table>
And I made template because I want to make a circle.
<style>
.main1_1{
    display: inline-block;
     margin: 0 auto;
.ok1_1{
  height: 25px;
  width: 25px;
  background-color: green;
  border-radius: 50%;
.middle{
  height: 25px;
  width: 25px;
  background-color: yellow;
  border-radius: 50%;
.low{
  height: 25px;
  width: 25px;
  background-color: red;
  border-radius: 50%;
.blank{
    border: 20px;
</style>
<div class="main1_1" >
    <div ng-if="msg.c_rate==100">
        <span class="ok1_1"></span>
    </div>
    <div ng-if="msg.c_rate<100 && msg.c_rate>50">
    <span class="middle"></span>
    </div>
    <div ng-if="msg.c_rate<50">
    <span class="low"></span>
    </div>
</div>
Let me know if this is possible.
Yes, it is perfectly possible. You will need to do some research on how to use Angular v1 which the Dashboard uses.
