Dashboard, ui_media problem, with node code (cont.)
Cont. to thred https://discourse.nodered.org/t/dashboard-ui-media-problem-with-node-code/42567, @Steve-Mcl, many thanks for your code, it works.
[{"id":"16302fa9.75087","type":"function","z":"5d3f964c.fef898","name":"to base64 img","func":"\nmsg.payload =  msg.payload.toString('base64');\n\nreturn msg;","outputs":1,"noerr":0,"initialize":"","finalize":"","libs":[],"x":1300,"y":2000,"wires":[["29f11527.839e1a"]]},{"id":"dd8f1ce6.3de7a","type":"http request","z":"5d3f964c.fef898","name":"","method":"GET","ret":"bin","paytoqs":"ignore","url":"https://picsum.photos/200","tls":"","persist":false,"proxy":"","authType":"","x":1090,"y":2000,"wires":[["16302fa9.75087"]]},{"id":"5b79d89b.5bf248","type":"inject","z":"5d3f964c.fef898","name":"","props":[{"p":"payload"},{"p":"topic","vt":"str"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","payload":"","payloadType":"date","x":920,"y":2000,"wires":[["dd8f1ce6.3de7a"]]},{"id":"29f11527.839e1a","type":"template","z":"5d3f964c.fef898","name":"","field":"payload","fieldType":"msg","format":"handlebars","syntax":"mustache","template":"<div>\n  <img src=\"data:image/png;base64, {{{payload}}}\" />\n</div>","output":"str","x":1120,"y":2060,"wires":[["db91e0b6.fb0c6"]]},{"id":"db91e0b6.fb0c6","type":"ui_template","z":"5d3f964c.fef898","group":"da148e61.f015f","name":"","order":5,"width":"6","height":"6","format":"<div ng-bind-html=\"msg.payload\"></div>","storeOutMessages":true,"fwdInMessages":true,"resendOnRefresh":true,"templateScope":"local","x":1290,"y":2060,"wires":[[]]},{"id":"da148e61.f015f","type":"ui_group","name":"Demo","tab":"da5706ae.6caf58","order":3,"disp":true,"width":"12","collapse":false},{"id":"da5706ae.6caf58","type":"ui_tab","name":"Home","icon":"dashboard","disabled":false,"hidden":false}]
Would you be so kind to give your advice on resizing the image, the problem is that the surveillance camera snapshot is very large, 8MP?
Do you mean you actually want the pixel count reduced (image resize) or that you want the image on the dashboard to be shown smaller (as in specifying the img width+height)?
If you want an actually smaller image (because 8mp is slow and bloated and over the top) then normally web cameras have alternative stream URLs for permit you to request a smaller image by using query parameters e.g. http://192.168.1.20/cgi-bin/viewer/video.jpg?resolution=640x480 http://192.168.1.20/img/snapshot.cgi?size=2 See here for more examples.
If you simply want the original 8mp image to look smaller on the dashboard, specify the viewing height and width using img attributes.
Unfortunately, requesting a smaller image is not possible. And sending the 8MP to the dashboard does not make any sense.
What I am thinking is that could node red reduce the pixel count.
In which case, node-red-contrib-image-tools can resize images and return a buffer or base64 for display on dashboard.
