hi there !
I have just installed node red and I wanted to try to make it work.
I perfectly started it and I tried to build up something.
Now the problem is when I'm trying to display the result in the dashboard in the browser using this link
' localhost:1880/ui/ ' I got this message back: ' Welcome to the Node-RED Dashboard
Please add some UI nodes to your flow and redeploy '.
I don't really understand what's going wrong with it.
can someone help me please ?
It might be because you havent used any of the dashboard node. Try creating an inject node and wiring it to a dashboard text node and then deploying the flows, close the ui page and try it again
I did it, but nothing works out
Did you make sure to force a full refresh the page in the browser (often Ctrl+F5 but may depend on OS and browser)
If still no joy then restart node red and, in a terminal run node-red-log
. Post the results here. That should show useful information about your system.
This issue came up for me when flows would not fully deploy.
I rebuilt a new machine, and started to rebuild node red flows one at a time.
But nothing in the dashboard works unless all flows have all their definitions. Missing nodes are shown dashed and will prevent deployment.
I have seen this with Internet Explorer - I suspect you are using Internet Explorer?
In fact, I'm seeing it now with dashboard version 2.13.0 on Node Red 19.5 and node-red 20 Beta3 (Corporate Environment - still forcing us to use IE11).
I haven't had time to debug this but from the errors in console, i suspect some functions that IE11 doesn't support are the issue? maybe?
Two errors I see are ...
Though these may be red herrings. Pictures are worth a thousand words ![:slight_smile: :slight_smile:](https://emoji.discourse-cdn.com/twitter/slight_smile.png?v=12)
Chrome...
![Chrome](https://global.discourse-cdn.com/business6/uploads/nodered/original/2X/5/534b3d16c4d9ae5e5b58763495a4a091b1460e24.png)
IE11...
![IE11](https://global.discourse-cdn.com/business6/uploads/nodered/original/2X/8/87e425b4cb2115b72fc0a371559c5edd946c4653.png)
Now as much as I despise the POS that IE11 is, we must (for now) support it ![:frowning: :frowning:](https://emoji.discourse-cdn.com/twitter/frowning.png?v=12)
Can anyone help resolve this?
Cheers.
Forgot to mention...
I'm fairly certain this happens when IE is in default mode
Try this...
- Open F12 (Press F12)
- Select the Document Emulation Mode drop down (top right hand side of "F12 Developer Tools")
Pretty Sure by default IE11 is set for Document Mode 5 (AKA as pile of crap MS attempted Web Browser Lock-in mode)
*Set this to mode 11 (or Edge if its available) - Dashboard will now work.
I suppose a new line of question would be - is there a way to have the Dashboard web instruct the document mode to IE?
Something like this...
https://msdn.microsoft.com/en-us/library/ff955275(v=vs.85).aspx
Interesting... I guess we could always add
<meta http-equiv="X-UA-Compatible" content="IE=edge">
If you think it would help ? Though as it's just in the dist/index.html
it should be easy enough for you to add locally to test for us ![:slight_smile: :slight_smile:](https://emoji.discourse-cdn.com/twitter/slight_smile.png?v=6)
I open the dashboard on an older machine with IE11 - one I have never used for node-red.
The dashboard did not display.
I added ...
... to dist/index.html
Hard refreshed browser (CTRL+F5)
Tada - worked.
NOTE: I cant be 100% certain it wouldnt have worked without this as now I cant get it to fail.
I suppose its no harm in adding the meta tag.
Thanks for letting me know... will do so.
(you may be able to set it to ..."IE=6" or something ancient to force it bad again... then forwards again to double check..)
