Here's another TWIST to the problem.
Stupid me, for not thinking about it before asking.
It is the LED node that is the problem.
Proof:
[{"id":"b3a9d953.59781","type":"ui_button","z":"650fc4d9.b1c234","name":"","group":"4632a740.ebbf2","order":3,"width":"2","height":"1","passthru":true,"label":"START","tooltip":"","color":"","bgcolor":"lime","icon":"","payload":"GO","payloadType":"str","topic":"topic","topicType":"msg","x":310,"y":2170,"wires":[["9c1406f9.08ad9"]]},{"id":"3050ac35.442324","type":"inject","z":"650fc4d9.b1c234","name":"Start","props":[{"p":"payload"},{"p":"topic","vt":"str"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","payload":"","payloadType":"date","x":170,"y":2170,"wires":[["b3a9d953.59781"]]},{"id":"9c1406f9.08ad9","type":"trigger","z":"650fc4d9.b1c234","name":"","op1":"1","op2":"0","op1type":"str","op2type":"str","duration":"-8","extend":false,"overrideDelay":false,"units":"s","reset":"","bytopic":"all","topic":"topic","outputs":1,"x":445,"y":2130,"wires":[["2c30784d.4572a8"]],"l":false},{"id":"5ed98b39.815b14","type":"change","z":"650fc4d9.b1c234","name":"","rules":[{"t":"set","p":"reset","pt":"msg","to":"true","tot":"bool"},{"t":"delete","p":"payload","pt":"msg"}],"action":"","property":"","from":"","to":"","reg":false,"x":395,"y":2130,"wires":[["9c1406f9.08ad9","2c30784d.4572a8"]],"l":false},{"id":"2c30784d.4572a8","type":"trigger","z":"650fc4d9.b1c234","name":"","op1":"1","op2":"0","op1type":"str","op2type":"str","duration":"3","extend":false,"overrideDelay":false,"units":"s","reset":"","bytopic":"all","topic":"topic","outputs":1,"x":465,"y":2190,"wires":[["c7978c8.4803cf","1cccc55c.b233a3","599b458a.6bbdec"]],"l":false},{"id":"577ab9b5.5cf1d","type":"ui_button","z":"650fc4d9.b1c234","name":"","group":"4632a740.ebbf2","order":5,"width":"2","height":"1","passthru":true,"label":"STOP","tooltip":"","color":"","bgcolor":"","icon":"","payload":"STOP","payloadType":"str","topic":"topic","topicType":"msg","x":300,"y":2130,"wires":[["5ed98b39.815b14"]]},{"id":"c7978c8.4803cf","type":"switch","z":"650fc4d9.b1c234","name":"","property":"payload","propertyType":"msg","rules":[{"t":"eq","v":"0","vt":"str"},{"t":"eq","v":"1","vt":"str"}],"checkall":"true","repair":false,"outputs":2,"x":590,"y":2190,"wires":[["5a0c2d27.827ff4"],["1d334193.2de09e"]]},{"id":"1cccc55c.b233a3","type":"debug","z":"650fc4d9.b1c234","name":"","active":false,"tosidebar":true,"console":false,"tostatus":true,"complete":"payload","targetType":"msg","statusVal":"payload","statusType":"auto","x":610,"y":2150,"wires":[]},{"id":"599b458a.6bbdec","type":"ui_led","z":"650fc4d9.b1c234","order":19,"group":"4632a740.ebbf2","width":"1","height":"1","label":"","labelPlacement":"left","labelAlignment":"left","colorForValue":[{"color":"#ff0000","value":"0","valueType":"str"},{"color":"#00ff00","value":"1","valueType":"str"}],"allowColorForValueInMessage":false,"shape":"circle","showGlow":true,"name":"","x":760,"y":2320,"wires":[]},{"id":"d83504bf.f1a18","type":"inject","z":"650fc4d9.b1c234","name":"Stop","props":[{"p":"payload"},{"p":"topic","vt":"str"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","payload":"","payloadType":"date","x":170,"y":2130,"wires":[["577ab9b5.5cf1d"]]},{"id":"5a0c2d27.827ff4","type":"change","z":"650fc4d9.b1c234","name":"","rules":[{"t":"set","p":"payload","pt":"msg","to":"<font color = \"red\" i class=\"fa fa-bullseye fa-2x\"></i></font>","tot":"str"}],"action":"","property":"","from":"","to":"","reg":false,"x":760,"y":2170,"wires":[["6442e48.ce5cc1c"]]},{"id":"1d334193.2de09e","type":"change","z":"650fc4d9.b1c234","name":"","rules":[{"t":"set","p":"payload","pt":"msg","to":"<font color = \"green\" i class=\"fa fa-bullseye fa-2x\"></i></font>","tot":"str"}],"action":"","property":"","from":"","to":"","reg":false,"x":760,"y":2210,"wires":[["6442e48.ce5cc1c"]]},{"id":"6442e48.ce5cc1c","type":"ui_text","z":"650fc4d9.b1c234","group":"4632a740.ebbf2","order":3,"width":0,"height":0,"name":"","label":"text","format":"{{msg.payload}}","layout":"row-spread","x":760,"y":2280,"wires":[]},{"id":"4632a740.ebbf2","type":"ui_group","name":"Shutdown","tab":"e395ddbe.f1d86","order":2,"disp":true,"width":"2","collapse":false},{"id":"e395ddbe.f1d86","type":"ui_tab","name":"DIAGNOSTIC","icon":"dashboard","order":7,"disabled":false,"hidden":false}]
Well, could someone check this and prove me right or wrong?
Scenario:
Two machines needed.
Both looking at one of the machine's Dashboard.
From the dashboard, press the START button.
The BULLSEYE will blink on that machine and the remote machine.
The LED will only blink on that machine.
Go to the EDIT screen and try there: LED will blink on both.
