I am working on IoT kit using Hilscher NetIOT Connect Gateway, I have a P&F Ultrasonic sensor, I am getting process data 14 bit in two bytes (attachment Received data). I want to convert it into 16bit uint starting 2-bit offset of the first byte, bit read starting from bit 2 to bit 14. So the value range from 0 to 4000mm.
Thanks in advance.
Br,
Devendra
