I am trying to send Temperature Value from analog Input of Galileo Board with opcua to server. My Problem is that I get error if I connect function Block to opcua node.
Could Anyone help ms to find my fault?
"id": "59be47a5.7dac58",
"type": "tab",
"label": "Flow 1",
"disabled": false,
"info": ""
"id": "7b527f17.f4e1d8",
"type": "OpcUa-Client",
"z": "59be47a5.7dac58",
"endpoint": "ccbe9b7b.6226d8",
"action": "write",
"deadbandtype": "a",
"deadbandvalue": 1,
"time": 10,
"timeUnit": "s",
"certificate": "n",
"localfile": "",
"securitymode": "None",
"securitypolicy": "None",
"x": 980,
"y": 200,
"c74189db.84ba58"
"id": "c74189db.84ba58",
"type": "debug",
"active": false,
"tosidebar": true,
"console": false,
"tostatus": false,
"complete": "false",
"statusVal": "",
"statusType": "auto",
"x": 1210,
"y": 200,
"id": "68d7416f.873218",
"type": "range",
"minin": "0",
"maxin": "1023",
"minout": "0",
"maxout": "100",
"action": "scale",
"round": true,
"property": "payload",
"x": 420,
"y": 220,
"3f8887c8.4e6b58",
"83ed62e1.6af1b"
"id": "a72a7ef4.81f088",
"type": "mraa-gpio-ain",
"name": "Raumtemperatur",
"pin": "0",
"interval": "1000",
"x": 170,
"y": 220,
"68d7416f.873218"
"id": "ceac519a.5fa0d8",
"type": "OpcUa-Item",
"item": "n=2;s=Tag18",
"datatype": "Int16",
"value": "number",
"x": 770,
"y": 200,
"7b527f17.f4e1d8"
"id": "3f8887c8.4e6b58",
"type": "debug",
"active": false,
"tosidebar": true,
"console": false,
"tostatus": true,
"complete": "payload",
"targetType": "msg",
"statusVal": "payload",
"x": 380,
"y": 300,
"id": "2196bf54.2ea58",
"type": "debug",
"active": true,
"tosidebar": true,
"console": false,
"tostatus": true,
"x": 760,
"y": 320,
"id": "83ed62e1.6af1b",
"type": "function",
"func": "var temp = Number(msg.payload);\nmsg = parseFloat(temp).toFixed(0);\nreturn msg;",
"outputs": 1,
"noerr": 0,
"initialize": "",
"finalize": "",
"x": 610,
"y": 220,
"ceac519a.5fa0d8"
"id": "ccbe9b7b.6226d8",
"type": "OpcUa-Endpoint",
"z": "",
"endpoint": "opc.tcp://192.168.2.202:55383/IntegrationObjects/ServerSimulator_IOT2040",
"secpol": "None",
"secmode": "None",
"login": false
Thx a lot
DerD
