Return value from OPC.IIoT.Result-Filter
Probaly an easy solution, but I'll ask anyway.
I have a connection to an opc server returning a value of type Float. Payload i returning the correct value until the value is 0. Then the value returned is an complete object. Why?
I'm also not able to set the correct number og decimals in the 'Convert'-tab
Can someone please help me?
Kind regards.
Show us what you mean by that. A screenshot of a debug node output would be good. Also show us what you normally get.
What node are you using to connect (node-red-something)?
Sorry for the delayed response.
Attached sample will show the problem. The OPC tag cycles from 0.0 to 1.0 in intervals of 0.25.
Each time the opc value is 0.0 the debug will raise an error. if the value is greather than 0.0 it will work.
Can you please help me understand why?
[{"id":"b0029f6e.de8b9","type":"OpcUa-Item","z":"44cfd37b.b7461c","item":"ns=2;s=Simulation Examples.Functions.Ramp2","datatype":"Float","value":"","name":"","x":640,"y":200,"wires":[["91d76d34.2067d"]]},{"id":"91d76d34.2067d","type":"OpcUa-Client","z":"44cfd37b.b7461c","endpoint":"e5d4719e.b6c15","action":"read","time":10,"timeUnit":"s","name":"","x":1180,"y":200,"wires":[["72e8e250.fe1e2c"]]},{"id":"91dd7360.7f467","type":"inject","z":"44cfd37b.b7461c","name":"","topic":"","payload":"","payloadType":"date","repeat":"1","crontab":"","once":false,"onceDelay":0.1,"x":190,"y":200,"wires":[["b0029f6e.de8b9"]]},{"id":"72e8e250.fe1e2c","type":"OPCUA-IIoT-Result-Filter","z":"44cfd37b.b7461c","nodeId":"ns=2;s=Simulation Examples.Functions.Ramp2","datatype":"Float","fixedValue":false,"fixPoint":2,"withPrecision":false,"precision":2,"entry":1,"justValue":true,"withValueCheck":false,"minvalue":"","maxvalue":"","defaultvalue":"","topic":"","name":"","showErrors":false,"x":1620,"y":200,"wires":[["b15ee614.ef1268"]]},{"id":"b15ee614.ef1268","type":"debug","z":"44cfd37b.b7461c","name":"","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"false","x":2360,"y":200,"wires":[]},{"id":"e5d4719e.b6c15","type":"OpcUa-Endpoint","z":"","endpoint":"opc.tcp://192.168.1.1:49320","secpol":"None","secmode":"NONE","login":false}]
Debug info:
"AssertionError: r.bianco.iiot),r.status({fill:"blue",shape:"ring",text:"new"}),r.bianco.iiot.nodeIdToFilter=function(e){var t=!0,o=a.core.buildNodeListFromClient(e);return o&&o.length&&(t=!o.some(function(e,t,o){return(e.nodeId||e).toString()===r.nodeId.toString()})),t},r.bianco.iiot.isNodeIdNotToFindInAddressSpaceItems=function(e){if(e.addressSpaceItems){if(o.filter(e.addressSpaceItems,function(e){return e.nodeId===r.nodeId}).length<1)return!0}else if(e.topic!==r.nodeId)return!0},r.bianco.iiot.messageIsToFilter=function(e){return r.bianco.iiot.nodeIdToFilter(e)&&r.bianco.iiot.isNodeIdNotToFindInAddressSpaceItems(e)},r.on("input",function(e){if(e.hasOwnProperty("payload")&&null!==e.payload&&void 0!==e.payload)if(r.bianco.iiot.messageIsToFilter(e))a.internalDebugLog("filtering message on filter");else{var t=Object.assign({},e);t.topic=r.topic||t.topic,t.nodeId=r.nodeId,t.justValue=r.justValue,t.filter=!0,t.filtertype="filter",t.payload=r.bianco.iiot.filterByType(t)||t.payload,r.justValue&&(t.payload=r.bianco.iiot.filterResult(t)),a.core.assert(t.payload),r.send(t)}else a.internalDebugLog("filtering message without payload")}),r.bianco.iiot.filterByType=function(e){var t=null;switch(e.nodetype){case"read":t=r.bianco.iiot.filterByReadType(e);break;case"write":t=r.bianco.iiot.filterByWriteType(e);break;case"listen":t=r.bianco.iiot.filterByListenType(e);break;case"browse":t=r.bianco.iiot.filterByBrowserType(e);break;case"crawl":t=r.bianco.iiot.filterByCrawlerType(e);break;default:a.internalDebugLog("unknown node type injected to filter for "+e.nodetype),r.showErrors&&r.error(new Error("unknown node type injected to filter for "+e.nodetype),e)}return t},r.bianco.iiot.convertResult=function(t,o){try{var e=null;return 0<=r.fixPoint&&r.fixedValue&&(e=Number.parseFloat(o).toFixed(r.fixPoint),e=parseFloat(e)),0<=r.precision&&r.withPrecision&&(e=Number.parseFloat(o).toPrecision(r.precision),e=parseFloat(e)),null===e&&(e=o),r.withValueCheck&&(e<r.minvalue||e>r.maxvalue)&&(e=r.defaultvalue),e}catch(e){return a.internalDebugLog("result converting error "+e.message),r.showErrors&&r.error(e,t),o}},r.bianco.iiot.convertResultValue=function(e){var t=e.payload;return null==t?(a.internalDebugLog("result null or undefined"),r.showErrors&&r.error(new Error("converted result null or undefined"),e)):(t.hasOwnProperty("value")&&(t=t.value),r.datatype?null==(t=r.bianco.iiot.convertDataType(t))?(a.internalDebugLog("data type result null or undefined"),r.showErrors&&r.error(new Error("converted by data type result null or undefined"),e)):t=r.bianco.iiot.convertResult(e,t):a.internalDebugLog("data type unknown - set the data type inside the result filter node")),t},r.bianco.iiot.filterResult=function(e){return("read"===e.nodetype||"listen"===e.nodetype)&&r.bianco.iiot.convertResultValue(e)||e.payload},r.bianco.iiot.extractValueFromOPCUAArrayStructure=function(e,t){var o=null,r=e.payload[t];return r?o=r.hasOwnProperty("value")?r.value.hasOwnProperty("value")?r.value.value:r.value:r:o},r.bianco.iiot.extractValueFromOPCUAStructure=function(e){return e.payload.hasOwnProperty("value")?e.payload.value.hasOwnProperty("value")?e.payload.value.value:e.payload.value:e.payload},r.bianco.iiot.filterByReadType=function(e){var t=null;return(t=e.payload.length>=r.entry?r.bianco.iiot.extractValueFromOPCUAArrayStructure(e,r.entry-1):r.bianco.iiot.extractValueFromOPCUAStructure(e)).hasOwnProperty("value")&&(t=t.value),t},r.bianco.iiot.filterByWriteType=function(e){return null},r.bianco.iiot.filterByListenType=function(e){var t=null;return(t=e.payload&&e.payload.hasOwnProperty("value")?e.payload.value:e.payload)&&t.hasOwnProperty("value")&&(t=t.value),t},r.bianco.iiot.filterByBrowserType=function(e){var t=a.core.filterListByNodeId(r.nodeId,e.payload.browserResults);return e.addressSpaceItems&&e.addressSpaceItems.length&&(e.addressSpaceItems=a.core.filterListByNodeId(r.nodeId,e.addressSpaceItems)),e.nodesToRead&&e.nodesToRead.length&&(e.nodesToRead=a.core.filterListEntryByNodeId(r.nodeId,e.nodesToRead),e.nodesToReadCount=e.nodesToRead.length),e.addressItemsToRead&&e.addressItemsToRead.length&&(e.addressItemsToRead=a.core.filterListByNodeId(r.nodeId,e.addressItemsToRead),e.addressItemsToReadCount=e.addressItemsToRead.length),e.addressItemsToBrowse&&e.addressItemsToBrowse.length&&(e.addressItemsToBrowse=a.core.filterListByNodeId(r.nodeId,e.addressItemsToBrowse),e.addressItemsToBrowseCount=e.addressItemsToBrowse.length),t},r.bianco.iiot.filterByCrawlerType=function(e){var t=a.core.filterListByNodeId(r.nodeId,e.payload.crawlerResults);return e.addressSpaceItems&&e.addressSpaceItems.length&&(e.addressItems=a.core.filterListByNodeId(r.nodeId,e.addressSpaceItems)),t},r.bianco.iiot.convertDataType=function(e){return a.internalDebugLog("data type convert for "+r.nodeId),a.core.convertDataValueByDataType({value:e},r.datatype)},r.withValueCheck&&(r.minvalue=r.bianco.iiot.convertDataType(r.minvalue),r.maxvalue=r.bianco.iiot.convertDataType(r.maxvalue)),r.status({fill:"green",shape:"dot",text:"active"})}"
Your flow is not importable. Please read this and then go back and edit your post so the flow becomes importable.
Sorry about that...
Hopefully readable now
I think the problem is in the OPCUA-IIO-Result-Filter node. If I remove this it works. Neither does the Convert function work in this node.
Sounds like you need to raise an issue against the origin of that node.
